Custom magnaflow axleback done!
ssmrico
Car: 2011 Infiniti M37 S
true yeah at that rate I can just get topspeed lol I have their intakes maybe match up exhaust too
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
DFW2011M56S wrote:
PostalsQ wrote:No mention anywhere of diameter size. You go with 2.5 inch? Cause I believe stock pipes are 2 inch???
If you remove the non monitored secondary cats the pipe is 2.5" at their inlets.
For the V8 you're right. V6 doesn't have non monitored cats. Stock pipes are 2".
armybrat
HPS intake hoses
Uprev tune
austin713 wrote:
dmclone wrote:Something looks wrong under there
yea i noticed that too. not sure how much a new cover costs.
That would be part #17285JK000, fuel tank protector. $47.40 at the estore.
austin713
Car: 2011 M37
have you bought that part? it doesnt look like the same shape at all.
DFW2011M56S
Car: 2011 M56S
On my 2011 M56S the pipes that exit the stock secondary cat were 1 7/8" and ran together into a 2.5" Y. The exit at the manifold cat going into the secondary cat is 2.5". I went dual 2.5" from the manifold flange to the back of the car. Woke my car up tremendously.
I could not even begin to tell you what the V6 runs because I have never paid attention to one.
armybrat
HPS intake hoses
Uprev tune
No I have not. The part schematics sometimes are not accurate, but it is a fuel tank protector. The part number might be stamped on the inside if you take it off.
armybrat
HPS intake hoses
Uprev tune
DFW2011M56S wrote:On my 2011 M56S the pipes that exit the stock secondary cat were 1 7/8" and ran together into a 2.5" Y. The exit at the manifold cat going into the secondary cat is 2.5". I went dual 2.5" from the manifold flange to the back of the car. Woke my car up tremendously.
Mine is the same except where it bolts on to the sport mufflers. Since the sport mufflers were made as a bolt on factory replacement, my exhaust tapers to 2" flanges at that point...thinking about modifying the sport mufflers to 2-1/2". It would be a lot of work though, plus I'm not sure it would get me any more performance.
