Custom Intake Manifold / What do you think?
Torpor
Car: 1993 Nissan 200SX (SA)
Good Evening Guys
One of my friend here with great skills made me a custom Intake. Please tell me what you guys think.
Side
Intake:
Sorry about the quick post but I will add information at a later stage
Buddyworm
Intriguing! Why no velocity stacks though?
bentvalves
Car: 89 Silvia K's
get it flowed and then only then will you know how good it is.
Greg
keep us updated!
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
Torpor wrote:Sorry about the quick post but I will add information at a later stage
Please do.
sideways danny
Car: s13, CA18DET
Buddyworm wrote:Intriguing! Why no velocity stacks though?
done the right thing IMO, stacks are just something in the way of flow. I much prefer a nice leading radius into the runner (which could be improved a little on this design IMO) but I like it!!!
Wish I could weld aluminium
float_6969
The results from a flow bench will tell the truth of the design.
Be wary, the guy that has that company that does nothing but intakes went through 3/4 revision for the CA before he got it right. He kept have problems with low flow in the #3 runner, IIRC.
progman
I agree with the above posts.
You have to taper the manifold just right in order for the airflow to be even. Just like what float said about one cylinder getting more or less than then the others. A setup like what Float described is very dangerous about hard to detect if you only have oxygen senor that read the aggregate all of the chambers (like after the turbo).
If could detonate one cylinder with you knowing.
If you do get this tested I'd be interested. Especially if your friend plans on selling some
And I have also read a lot of places that bell mouthing the ports almost always helps. Maybe consider that if he does a revision.
mbmbmb23
progman wrote:I agree with the above posts.
You have to taper the manifold just right in order for the airflow to be even. Just like what float said about one cylinder getting more or less than then the others.almost always helps. Maybe consider that if he does a revision.
Or you can just try and adjust each individual velocity stack for length until the air flow is equalized between chambers. I'm not sure if the total adjustability can overcome a non tapered design tho....but it's worth trying out if you already have the shell made. You can also try using different diameter stacks to increase or decrease the air speed.
Torpor
Hi guys...
Sorry about the lack of information, OK the intake is still in the R&D phase. We are just working out the fitment issues as for the guy that made it he has more then enough expertise for me to trust the man.
He has mostly only worked on boosted projects, like 4AGE turbo’s, 7M, and has built his own intakes for those projects he is also currently building a 1UFE 200sx Turbo.I really can’t wait to fit the thing, I’m going to smooth out the runners and she will only be running a 60mm TB
biosehnsucht
Don't care how established he may be, you couldn't pay me to run that on my engine untested. Flow test it!
Search far enough back in the archives there's various discussions on custom manifolds that have been referred to here in this thread..
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Flowbench or bust.
bentvalves
Car: 89 Silvia K's
hey man before you go installing that, lets get some flow bench numbers posted.
If the thing flows well enough, you might be suprised how much interest we show in that product.
Im building another CA atm.
sideways danny
Car: s13, CA18DET
drama queens the lot of you. numbers aren't everything, sometimes actually fitting something to try it can tell you a hell of a lot more
biosehnsucht
I'm not concerned that it flows alot, just that it flows evenly :D
certainly if it was way lean or rich in one cyl, that would be bad!
float_6969
Exactly. I'm sure it's got greater total flow. But what if it looses bottom end? What if the flow rates aren't even between the cylinders? Unless you had O2 sensor on each runner, you wouldn't know until you leaned that cylinder out and damaged it.
You need to put it on a flow bench and test each runner for flow against the other runners.
Torpor
**** Update****
Hi guys here are some updated pictures of the R&D fitment.
Intake Removed------------------------
Test Fits -----------------------
Blurry Pic of the Port-------------------------------
Problem Area's-----------------------------
The Water line running under the intake need to be re-routed
Quick question to all the guys on the fourm there is a Pipe leading from the thermostat intake manifold (Pic 1) under the old intake to copper hard line under the intake (pic 2) .
Can this Pipe be removed and If not why? I know it could be a water cycle but my thermostat says partially open so can it be discarded
Thankz
(Pic 1)
(Pic 2)
bentvalves
Car: 89 Silvia K's
sideways danny wrote:drama queens the lot of you. numbers aren't everything, sometimes actually fitting something to try it can tell you a hell of a lot more
go figure......at what cost.
Unless he has 4 EGT probes mounted in each exhaust runner, or he wants to be taking plug readings on the side of the highway (WOT, key off, coast down) to see what the spark plugs have to say, then I would seriously consider flowing it.
thats just me though.
dash
Car: s13 ca18
I'm all for custom work & trying stuff,but....At what point would you wanna get rid of the fine performing stock intake tho ? Chasing a 'peak hp number'.... race car ?It has made well over 400 ft-lbs tq on street CAs
Torpor
I think there is a little confusion here , I'm not asking for approval from you guys to install this intake,I will not be crying on your shoulders should my motor fail. I accept your warnings and support thank you very much for this.
Now lets move on because I will not be removing the manifold can anyone help me with the bellow question.
I have found One picture on this forum where the member has bypassed the inlet
Can this Pipe be removed and If not why?I know it could be a water cycle but my thermostat says partially open so can it be discarded
float_6969
It feeds coolant to the oil cooler and heater core. If you don't care about heat and will install an aftermarket oil cooler, then yes, you can ditch it.
Torpor
Thank You Man
float_6969
NP.
Torpor
Ok, the Car does run alot hotter and there is a sucking sound comming from the intake (Maybe to be expected).Does anyone have the same sound from theres? Will double check for air-leaks
Had to extend 4 Connections (TPS,Idle control, Aircon, FICD) . High Idle still works along with the Air-con control valve.
Car seems flat down low (Also expected), I will install a new set of plugs then give her abit of a run like recommended. I will post the pictures of the plugs.
Thanks again Guys
Installed pic's
Modified by Torpor at 9:14 PM 2/4/2008
float_6969
Good luck. Can't wait for the plug pictures.
Also, the intake from the intake building company in Austrailia didn't loose any bottom end.
Torpor
Ok Guys due to the Fact that Photobucket was having issues last night, I couldnt post the Pic's of the plugs yet.
I will post them tonight
Torpor
OK , the car is running at 8 PSi and 16 deg of timing
Plugs are from right to left (1-2-3-4)
float_6969
#4 looks like it might be a little leaner than the rest.
Better pics of the porcelan would help too.
IggyEGuana
Car: 1986 200SX S12
I like it. Any thoughts of doing one to replace the whole manifold. Maybe relocate the injector and fix the problem with fuel only going through 1 valve.
http://www.driftopia.com has a bunch of real good tech articles on the CA and one of them is about simplifying the cooling system. Will answer your questions on the coolant lines.
Torpor
Car is going Strong. Plugs are looking good.
I admit, I did have to fiddle with the ignition timing and fuel pressure a bit, She is running at only 8 psi (0,5bar) and is as smooth as silk
I really don’t think its to bad for a $200 part.
float_6969
Just keep an eye on the plugs and make sure you're not seeing any big differences between them.
If you don't, then I think you did well, as long as it makes more power.
