Mettler wrote:Listen here, I find it necessary to reverse engineer the valvetrain when you consider we're dealing with an engine that has VTC, and a finger rocker design prone to failure if ramp rates are too steep & valvetrain geometry has changed. Is your beloved cam grinder even designing the cams to work with VTC, for a street motor? And if so, is he designing them to the absolute limit, and to achieve the highest possible Dynamic Compression Ratio, whilst remaining reliable on pump gas?
Oh wait, no, all he's doing is making a generic profile that gives you big overlap at the highest RPM, at the expense of decent cylinder pressure at the lower revs. Sure, this is fine for a guy like you who wants to drag race, who could theoretically slap his VH45DE in a sports car, thrash the crap out of it and blow it up, then just rebuild it at a whim since you work at a reconditioner.
You might find it neccessary, but you new to engines and you are no cam grinder or valvetrain engineer... maybe if you weren't just learning about how cams affect engines when I was cutting up VH heads, you would have a little more credibility. Everything that has come from you is purely speculation. I'm designing my cams without VTC, but also it's not rocket science to implement a cam design to work with a VTC system. My cam grinder grinds cams for all kinds of racing sanctions and OEM's that you've never even heard of, I'm going to listen to him about what he reccomends based on the specs of the engine and the heads, not some kiwi who has just learned about doing it but hasn't ever done anything. The guy who's grinding my cams did the cams for the beloved supercar nissan v8 engines, I think he knows a thing or two about the application. You're no expert, mate, and I build engines that last under high power and stress.... you??Quote »
What about guys with Q45s who just want a bit of extra power throughout the powerband, as well as significantly increased peak HP, but not at the expense of driveability? Your huge cams are not going to be good for cars like that at all.[/quote] Grinding an economical profile isn't as hard as you are making it out to seem, have you even talked with a reputable cam grinder or are you just making these assumptions based on things you read and come up with on your own?
Quote »Had you even considered the engineering complexities involved too? For example, having to drill a straight 6mm hole more than 250mm deep through the middle of a billet of high carbon 4140 steel roundbar for the oil gallery inside the cam? Planning the methods, making the right enquiries, and collecting the tools to make it happen, all takes good time. Time that's being well spent to ensure it's done right.[/quote]There are no complexities with the engineering, as long as you have a good machinist, gun drilling a cam is NOT hard. You are making it out like it's really rocket science.
Quote »Begging? Don't talk bull****. Way to be a colossal douchebag about it... like a typical aarogant ****wit, you didn't even reply or discuss things. Do not, for even a second, think I'm gonna take this from you. You can't appreciate anyone else's hard work and efforts but your own. It has nothing to do with glory, thunder, whatever... way to go and create a strawman argument. You're the ****ing glory whore here.[/quote[]Yeah, I'm the one who is all up in everyone's cam threads always making replies and threats about them putting me under.. get real man, look at your first posts in this thread... you are just trying to hog all the glory about making cams. I appreciate hard work when people have results, I don't appreciate all this talk about nothing and keeping everyting secret. Notice in my threads that I make, I not only have pictures but detailed explanations of everything I've been doing.. If it's not about having glory, then why on earth did you get so butthurt and lock your thread at even the mere mention of getting Brian Crower to come up with a set?? don't lie to yourself man, you're just upset that all this effort you're putting out for nothing is going in vain because you are too stuck on yourself to realize that you aren't the king **** of engines and camshafts.
I'm pissed off because rather than communicating, helping me, offering suggestions & working with me to make it happen, you're doing the exact opposite. I've had a passion about doing this for ages... but for your cam grinder, to him it's just another set of cams to add to his catalogue. That's what annoys me.
You keep everything secret, and you just expect me to hand out all of this information to you so you can milk it? double standard? you're a complete forum tool "m8". You might have had passion for doing this for ages, but by reading your posts when the vh forum was made you were a pretty green newb and had to read everything you know now. You think you know more than cam grinders that have setup a name and reputation for themselves, and who are actually established in what they do... that's what annoys ME.
Quote »That's fine, no doubt they're going to be good for your very narrow focus application. Don't forget to update us all when you blow your motor up. At least you can bet that when I produce my set I'll have before & after dyno proof of results, as well as being able to say that a year's worth of R&D has gone into them, rather than just slapping a generic grind on.[/quote]Yeah, you're one to talk about blowing motors up... how's that stock motor going by the way? Like I said, I have a reputation and actually have alot of engines out there that are making power and not breaking... Who are you kidding, you're not going to get the cams (let alone dyno charts) anytime soon, don't kid yourself or any of us anymore. It's easy to talk all this smack, but to back it up you actually have to have results... and have accomplished something.... which apart from putting a stock motor in an old car and blowing it up, you haven't done.
Quote »Hook me up with some money then, critic. I've already bought the material for the cams & have it sitting in my office at work, and I have the machining drawings done. Our CNC lathe operator has left the company and gone overseas, and I don't have the cash to pay another engineering company to machine up the blanks for me. So saying that I'm never going to get them done.... pffft, don't make me bitchslap you. If you're on the edge of your seat and want to see some hard results from this, why don't you lay down some cash?[/quote]yeah, big e-tough guy... I've seen videos of you mate, and I'd smash you into the ground before you even knew what happened. I lay cash down into people who are established and who give results, not an amateur kiwi who isn't established and is just learning about engines.
Quote »You're not productive whatsoever, you have offered nothing to contribute to the project, but you're all too happy to sit there and bash me for not being able to make progress due to factors out of my control. Another way to describe that is 'being a bastard.'[/quote]listen mother****er, I've done alot more with VH's than you can even dream about, all you have to do is look at my threads and pictures.. I've done all kinds of boring, cross section cutting, all kinds of headwork, and I have everything in pictures and notes... It won't take a genius to look at all of my previous posts and see that I've done alot of research and experimental work on VH's.... when's the last time you cut up a head, block, and crank?Quote »I intend to do so this year, and what will get the price down will be a group buy. e.g. upgrade valvesprings that allow 1/2" lift, I can get 64 made at a price of $11NZ each (that's around US$8 each). So imagine if I was to get say, 5 sets done at a time.[/quote]That's great, I hope for the rest of the people on here that you are able to do that.. Quote »Finally, this is not the place to argue, do it over e-mail. It stops now.[/quote]**** that, I'll argue where I want to..
