How many people have checked the valve lash on their stock setup? Could have been slightly out of spec to start with.Florida240sx wrote:The V2's are a drop in affair. But you need to check clearances. They are suppose to be within factory spec. You always need to check regardless.
Correct!Florida240sx wrote:The V2's are a drop in affair. But you need to check clearances. They are suppose to be within factory spec. You always need to check regardless.
You might find this link interestinghttp://forums.nicoclub.com/zerothread/184025drb930 wrote:Do you know of anybody or a thread that has the Actual Duration, Lift, and Lobe Separation at .050 lift for some of the cams out there like the early S13 cams, S14 cams, JWT, and all the Crower Cams, ect?
Thanks,Dave
The intake cam will have the dowel pin in line with the first set of lobes while the exhaust cams will not.97s14pwar wrote:i just got mine home today, how do u tell which one is the intake and exhaust. and how are you suppost to break them in?
Here are the Crower cam specs for you:drb930 wrote:Do you know of anybody or a thread that has the Actual Duration, Lift, and Lobe Separation at .050 lift for some of the cams out there like the early S13 cams, S14 cams, JWT, and all the Crower Cams, ect?
Thanks,Dave
