^^^We have covered this before but just for the sake of keeping the thread bumping... PDM-Racing might have cams for the KA24DE and claims it has turbo cams, but it has NO dyno sheet proving the turbo cams work, especially compared to the Crowers. Remember the Crower V3's hit a peak of almost 50rwhp on a Mustang Dyno when Ivan tested them, and they gave HUGE area under the curve gains. I for one will wait until Crower actually has them available before I attempt to buy them. My head has been built around those stupid V3's ever since last spring.grimple1 wrote:just 2 more weeks....
pdm-racing.com has colt cams for the ka24de
Incorrect. Anyone with ANY ability to alter there A/F ratio will benefit as much as Ivan did. We had a thread on this and Ivan even said that the gains would be approximately equal. The V3's will need additional fuel because of the amount of air they are moving. So essentially all you will need is to add fuel so you don't run lean. That's all the tuning you will need for the cams. I speak only for the V3's because I don't care about the V2's. So even people with an AFC can "tune" for the cams.dsylvia wrote:not to bash the crowers, cuz i plan on getting them too.
but ivan was able to get the really high hp increase with them is becuase he tuned the EMS to work best with the cams. the majority of users will probably not be able to do this. so power gains prolly will be lower for us other folk.
they'll still be awesome cams though.
HolyShiznit wrote:Incorrect. Anyone with ANY ability to alter there A/F ratio will benefit as much as Ivan did. We had a thread on this and Ivan even said that the gains would be approximately equal. The V3's will need additional fuel because of the amount of air they are moving. So essentially all you will need is to add fuel so you don't run lean. That's all the tuning you will need for the cams. I speak only for the V3's because I don't care about the V2's. So even people with an AFC can "tune" for the cams.
It should also be noted that, as seems to be the trend lately, the V3's seem most suited to dyno-queens and drag people...50 rwhp, along with a substantial loss in torque, which coupled with the massive turbos everyone runs now (that are needed to make this 50 rwhp gain), will make the lag even more painfully slow...Don at PDM is an actual race car driver...and an avid autocrosser, so I'm sure his cams are far better suited to day-to-day driving where some people would like torque below 5000 rpm. 50 rwhp doesn't come from thin-air, remember that. It's all about compromises. I just don't understand how everyone lives with laggy turbos and low torque--i thought almost everyone on here drove their KA-Ts daily?!?!HolyShiznit wrote:
They got them for the NA cams though.HolyShiznit wrote:
^^^We have covered this before but just for the sake of keeping the thread bumping... PDM-Racing might have cams for the KA24DE and claims it has turbo cams, but it has NO dyno sheet proving the turbo cams work ...
is 599 ft.lbs considered low torque?...Heath and Keith's 638whp/599 ft.lb KA actually had alot of HP/TQ even across the low to mid range. im looking at the dyno sheet right now and the powerband is actually quite impressive.MarkEmark wrote:I just don't understand how everyone lives with laggy turbos and low torque--i thought almost everyone on here drove their KA-Ts daily?!?!
Did you even see the original dyno graph? There was almost NO loss in torque, peak torque went up by 30 if I remember correctly and the only "loss" came at 3800 where it was down 7 from the stock cams. Also it was proven that it spooled the turbo faster than stock cams... I have no idea where you read all the problems. According to Ivan and the back to back dyno graphs the V3's essentially kept the stock torque curve while allowing faster spool up and MUCH more top end. The gains across the board resulted in a MUCH better power curve than stock. Also remember that the V3's were designed for 20+ psi and require stiffer valvesprings/titanium retainers.MarkEmark wrote:
You guys are missing the point...of course that's a lot of torque...that's an incredible amount of power. I'm clearly not alluding to the highest HP KA's ever created with insanely good, professional tuning.klattr1 wrote:is 599 ft.lbs considered low torque?...Heath and Keith's 638whp/599 ft.lb KA actually had alot of HP/TQ even across the low to mid range. im looking at the dyno sheet right now and the powerband is actually quite impressive.
I wouldnt give anyone any money for these cams until I actually physically see them in their box right in front of me. Crower has set (and missed) dates on these cams LOTS of times now, so it shouldnt be any suprise that this February deadline was the same old story. They probably have a product number for the part already, which is most likely why your guy thinks he can just call up and order the cams-- but guaranteed, they're not available from the factory yet.Hard_Limitz wrote:I then gave Eric a call at BnE Customs and he said he could get them for $399 and that they were available from Crower. I am hella confused now.
