Wow...that looks badass.evildky wrote:the L28ET is the cheapest, you just gotta find a good donor 81-83 280ZX Turbo, I've bought 3 of them and nto paid mroe than $400 for any of them, that gets you the engine, hanress, ecu and all the bits needed, and you don't have a buch of little itesm to run up the cost as it's still an L6 and just bolts right in, turn the boost up to aobut 9psi and enjoy arouns 200 whp, then you can add an intercooler and turn up the boost to about 15 psi and get to around 150 whp, then you can save up for the big mods all at once, and for engine managment Megasquirt is a real bargain
if however you prefer a domestic V8 the chevy is much more common and easier than ford or dodge, you just have to make some spacers and setback plates to locate the engine fab trans mount, have a driveshaft made etc
JTR (Jags That Run) made a book all about it and you can still buy the book, hybridz.org caters to engine swapped S30's of all variations, but yoiu'll want to do a lot of seearching and reading before asking any questions there
I personally really like and almost did the VG30ET swap, it requires a custom drivers side exhaust manifold but it'l locate the turbo up front where you have tons of room witht he V6
my monster L28ET 2100 lb 240Z
you need the correct Harness, ECU, Distributor, AFM form an 81-83 280ZX Turbo, rpeferably the 82-83 as they changed the 81 is a bit uniqueskylinedriver59 wrote:What kind of ecu you do I need? will any 280z ecu work or only the one of a turbo? Is there an ecu number or code to identify them?
if you want 200 whp form an n/a L28 you'll want to run tripple side draft carbs or if you prefer injectiron, stand alone ecu, of even z31 ecu conversion, and I've seen one guy do a turbo electronic's conversion, anyhow, a good headergood ignition systemfree flowing mandrel bent exhaustbumpy cam high compression pistonsN42 cylinder head or a P90 mechanical shaved by .80 and then shim the cam back upit's a lto cheaper to make power with a turbo!I got one local bub who made a short stroke 2.8, kept the L24 crank and rods, alsong with custom pistons and a .80 overbore on an L28 block, alson with an E31 head modified to accept larger valves, tripples, headers, crane ignition Nissan motor sports L7 cam and made 186 whp, he has since upgraded to an L9 cam and upped the jets in his carbs, he's confident he's at about 200 whp now we'll find out at the syno day this springRagingPanda wrote:evildyk...can you provide me the link or infos on turning the L28E into 200whp?
skylinedriver59 wrote:can some one answer my question more clearly
I found a L28ET just the motor no trans or ecu. So here is my plan Can I get the L28ET slap my trans buy or pick up an ECU from a local junk yard or buy one if I find one on ebay or something?How does that sound and Will that work?
yes it will bolt to your trans, other than the trans what part wasn't clear?evildky wrote:you need the correct Harness, ECU, Distributor, AFM form an 81-83 280ZX Turbo, rpeferably the 82-83 as they changed the 81 is a bit unique
the stock fuel pump for the 240Z is a mechanical one on the side of the block, it's built for a carb'd motor, which is extremely low PSI and EFI runs at a much higher PSI... So no, it will not work for a fuel injected engine, much less a turbo motor.skylinedriver59 wrote:I also forgot to ask about the fuel pump? do I have to change it to a 280zx turbo fuel pump or will the stock 240z work?
well there goes my hopes and dreams of making a s30 with a vq in it lol. That looks way out of my league of fabrication lolzevildky wrote:here ya gohttp://www.vq240z.com-a.googlepages.com/
