evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Sep 24, 2008 5:38 am
don't run the power for the coil tot he batery, it needs to be switched cranking power, the stock power wire tot he coil should be fine, you just have to have a course that stays hot while cranking, most accessory circuits go dead when cranking, if your power source to the coil is dead when cranking it will not start
the write up seems to be pretty much spot on except the ignition plug and CAS plug, which is the major difference for the 81 model, the diagram he posted at the bottom is actually the 82-83 harness diagramthe less graphic discription is actually the one I used when I did my swap, make sure you ahve a good connection at all your grounds, make sure all your hots stay hot when cranking (if the ecu has no power when cranking the car will nto fire either), verify that the fuel pump is powering on and that the fuel injection relay is powered up, unfortunately the ignitor is a common point of failure on these, after 30 years and 100k miles they tend to weak out and are extrememly expensive and had to find, also it must be grounded to the chassis to work
just take your time, check everything over, and if you cna locate another ignitor it might be worth hanging onto
