Crank pulleys/Harmonic balancers- get your learn on!
PapaSmurf2k3
Site Admin
So my Miata's crank pulley is starting go go :eek:
The crank angle sensor runs off the crank pulley, and its starting to slip (my base timing changes slowly after time). While not exactly the same, picture teeth on the outside of the blue disc in this picture:
The teeth are rotating in relation to the crank.
So I pop on Flyin Miata for something else, and run across this:
http://www.flyinmiata.com/index.php?dep ... %201991-95
Now at this point in my automotive career, I've seen the straight underdrive billet pulleys (undamped), and also know that damn near all OEMs have a pulley with a damper in it, so there must be a reason. I also wondered why a higher horsepower engine would require a better damper (not including a supercharger- something that puts more load on the crank pulley). I thought "the crank pulley shouldn't care... it just sees spin. It shouldn't care if its in neutral or 6th gear".
This handy-dandy article explains things really well:
http://www.atiracing.com/products/dampers/101/index.htm
and http://www.atiracing.com/products/dampe ... _dinan.htm
Essentially, under higher horsepower applications, the crank becomes a torsion spring. It "twists" elastically, and the crank pulley helps to dampen those spring oscillations.
RicerX
Car: '20 Titan Pro4X
I missed this the other day. Well done sir!
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Dropping knowledge bombs. I like. I've always wanted ATI super damper, but am never in the right place monetarily to drop that kind of dough.
PapaSmurf2k3
Site Admin
The install is looking pretty serious. Basically disassemble the entire front end of the engine. Pull the timing belt out, and then you have to use your old crank pulley bolt to actually press the ATI damper onto the crank. Pull it back out, and then use the newly supplied crank bolt. Then do your timing all over again, all accessories/belts/etc.
Hijacker
Car: '92 240sx Convertible
'94 F-150
An ATI damper has been on my list of things to get for the SR for quite a while. People tend to forget that ironing out harmonic issues on rotating assemblies tend to help power output.
