crackling sound?
Post all your Nissan electronics, car audio and stereo questions here!
mryzza
Car: 1992 Infinity Q45
I was listening to my IPOD full blast in my Q45 92 and then the song changed and the new song had a REALLY loud bass. So then after that I've had a crackling sound around one of my rear speakers. It's as if the frame in which the speaker sits is lose.... I don't really know much about car audio so I need some help figuring out what happened and how to fix it.
Notorious170
Car: 1998 Nissan Altima Bagged *Totalled*
2005 Dodge Magnum R/T Bagged
mryzza wrote:I was listening to my IPOD full blast in my Q45 92 and then the song changed and the new song had a REALLY loud bass. So then after that I've had a crackling sound around one of my rear speakers. It's as if the frame in which the speaker sits is lose.... I don't really know much about car audio so I need some help figuring out what happened and how to fix it.
sounds like you tore the surround of the speakers.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
That would be my guess also. Just take them out and see if the foam is separated.
PoorManQ45
Replace them.
They're standard 6x9 size.
Pretty much anything will be better, but I'd suggest Infinity or Focal.
mryzza
Replace the speakers? Where would I get new ones?
PoorManQ45
LOL.
Best Buy, circuit city, tweeter... etc...
mryzza
So I can't fix the problem myself without buying brand new speakers?
PoorManQ45
LOL, brand new speakers will cost you between $20 and $100 depending on what you like.
I think you're talking about getting new bose speakers.
I don't ever recommend that
mryzza
Ok, **** it, I'm gonna buy 2 new rear speakers. Any1 got any pointers for what I should look? I want to spend under 100 dollars too. Also are there any other specifications besides the 6 x 9 measurements?
Modified by mryzza at 3:01 PM 10/18/2006
PoorManQ45
Nope.
No other specifications.
Just go to whatever local store you have and bring a cd that you're familiar with. Listen to the different speakers.
Don't automatically pick the loudest one. Listen for the actual sound. Whatever ones you like are the best for you.
Just stay away from brands like pyle, pyramid, lanzar, audioban, punch, boss, ect...
mryzza
Why should I stay away from those brands? What brands do you recommend?
PoorManQ45
Just stay away from brands that claim to offer amplifiers that have a very high output for only $100. Like lanzar claims to have a 1000w x 2 amp for $200. In reality it will put out ~50watts x 2
How about this, just go to best buy. The only bad brands they have are dual, verse, and crunch. Everything else they carry is decent
mryzza
Also, howmany watts should I get? Should I get the speakers with the same number of watts as the original speakers or can I get speakers with more power?
PoorManQ45
Doesn't matter.
25~100rms will be fine. Don't pay attention to the "max" or "dynamic" rating
mryzza
Well I went to Best Buy and the cheapest 6 x 9 speaker was around 62 dollars each. I think I'm gonna try overstock or ebay instead.
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Don't worry about getting some crazy 3-ways or 4-ways. A good 2-way will work great. Trust your ears!
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
My rear has a crackling sound too, but I just replaced them so I think mine is either a loose base, loose connection or bad ground..
mryzza
So basically even if I replace them I might still have a crackling sound?
PoorManQ45
Damnit, just go to walmart.
They sell roadmaster 6x9s for $20 a pair.
Believe it or not they sound decent
Looneybomber
10 G37S (white)
mryzza wrote:So basically even if I replace them I might still have a crackling sound?
Depends if the speaker is making the noise, the mount it attatches to, or the cover over them. Get your ear by there and start to figure out where the sound is coming from. That or send it into an audio place, have them diagnose it for you and sell you whatever you need. Expect to pay well over 100.00!
PoorManQ45
This is a damn G50!
There is no plastic mount! It mounts directly to the metal rear deck!
The amp shouldn't cause it to crackle, but it's a possibility.
I suggest that you change the damn speakers. If that doesn't fix the problem you can add an aftermarket amp!
Either way you have to change the damn speakers. You can't use an aftermarket amp with the bose speakers. They are 1 ohm. This will kill any other amp
mryzza
Here's what I am looking at right now.
http://www.circuitcity.com/ssm...#tabs
I kinda liked my factory ones... Good bass for me, I think. Which one of these do you is the best for the Q?
PoorManQ45
Either will do, but I personally like these:http://www.bestbuy.com/site/ol...84508h ... ol...84856
You can get both of those online for less then that.
They will produce alot more bass then the sonys too
mryzza
Ok, I like these ones: http://www.bestbuy.com/site/ol...84508
That's the first link you posted. I found them for 80 dollars on the net, however. The depth for the original speakers is 5'' and for these ones it is 3''. Does this matter or not?
mryzza
Ok, lets forget about which speakers to buy for now. Right now I am wondering how I am going to remove the speakers. I removed the cover in the trunk to try to get them out from there but it seems like I would need to remove the back seats?
Also, I was browsing the net and I found this : "And aftermarket speakers cannot be used with the factory system without an aftermarket amplifier and $500-$600 worth of rewiring and impedance modifications. If you want to save money, just head to a junk yard and pick up replacement Bose amplifiers for $30. "
http://www.epinions.com/content_100511026820
Is that true?
PoorManQ45
That is not true.
You can use the bose amps with aftermarket speakers. A few people on here have done it, including myself.
To get the speakers out you do have to take the back seat out. Then you pop up the rear deck.
mryzza
Alright then, I am going to order the Infinity 3 way speakers you showed me, I found them for 80 dollars on another website.
Also, I was talking to my friend and he was wondering if the head units would match. Is this a problem? My friend said he doesn't know much about old foreign cars and he wasn't sure if the head units would match.
PoorManQ45
Not sure if the head unit would match what?
What you're going to have to do if take the amp off of the back of the original speakers.
The amp is the black thing on the back of the speakers. Unscrew both of them(one for each speaker). Then there is a red(pink?) and a green wire that actually goes from the amp to the speaker.
These are the wires you'll need to cut. Cut them as close to the speaker as possible. Then either use a wire nut or solder to connect about a 12" piece of 14~16awg speaker wire to each one of these.
Then you need to figure out a way to mount the amps. You can do it however you want. I pesonally just hung it from the new speakers. But you could easily velcro then to the underside of the rear deck.
mryzza
Ah, so each speaker has its own amp? I didn't know that.
So how should I remove the amps? Should I unplug them first and remove them with the speakers through the inside of that car?
Also, when I solder the 12'' wire to the amp wire, how do I connect the amps to the new speakers?
PoorManQ45
mryzza wrote:So how should I remove the amps? Should I unplug them first and remove them with the speakers through the inside of that car?
That's the easiest way
mryzza wrote:Also, when I solder the 12'' wire to the amp wire, how do I connect the amps to the new speakers?
By whatever method the Infinity speakers you bought uses. More then likely it'll be a spade connecter. If that's the case then you can pick up the proper sized spade at any hardware store. Or it'll be push pins. With this you just strip back a little bit of the wire. The push and hold the pin while you slide the wire through tthe hole
