blackeagle113089 »
https://forums.nicoclub.com/blackeagle113089-u41670.html
Wed Aug 30, 2006 8:13 am
ok i have a few questions bout my 1994 q45
1. The relays for the TCS under the battery, what is the part number and who can I get it from thats pretty cheap (online? store?) ? I need to replace those because the TCS Off and Slip lights are on.
2. Someone cut me off and I ended up shattering my Passenger Side turn signal lamp, where can I get one of these to replace it? Anywhere online?
3. The cable in the driver side door thats in the motor for the power window busted, so I'm assuming I need a new motor because that cable cannot be replaced. not to mention it is also twisted and tangled in there. Same question, where can I get a new one for cheap? (junkyard is out of the question, i checked)
4. Spark plugs and wires, since I bought the car a few months ago, I want to give it a good tuneup. The car tends to shake a bit when idle-ing. So I want to change the plugs and wires. Same question. How much does it cost and where can I get them?
5. The little switch for the sunroof, to open it and close it - it kinda broke off cause someone was pushing it too hard... Can this switch be replaced? Where Can I get it?
6. Do the fog lamps use the same bulb as the low beam headlights? I believe its 9003 or H3 or something? I was thinking of replacing the headlights with some silverstars and just moving the low beam lights down to the fog lamps cause one of the fog lamps are blown.
7. The q45 has a high beam bulb and a low beam bulb right? so if i replace the low beam bulbs with brighter ones, then i need to replace the high beam bulbs with even brighter ones?
8. The airbag light constantly blinks all the time. Why?
9. The a/c only blows on high, anything below that, its like its off. Why?
Thanks for the help!!! nico is awesome!
Modified by blackeagle113089 at 11:38 AM 8/30/2006
