C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Oct 13, 2005 3:36 pm
So do you draw the line for performance car by weight? If that's the case, you can gripe about the M3, M5, and RS6(4,000 lbs) too. Yet they will probably outperform most cars on this forum.
Is 3200-3300 that much better? The Enzo and Carerra GT fit into this weight range but will outperform any car in here all around. The 06 Z is more than 3300 even for the base model. Is a stock 240sx considered a performance vehicle then?
When I look at performance and just about everything else, I look at the bottom line. What matters most are the results. If I had a 10,000 pound car that would perform as well as an Enzo, I'd still call it a performance car.
And if it's dead weight you are worried about, I assure you it's not. Part of the reason for this dead weight is the exceptional Chassis Rigidity, and very good safety ratings. The car has generous use of aluminum(suspension and hood), which would be more in tune with performance than steel parts. A very beefy and solid 6-speed transmission also contributes to solid performance(It is likely stronger than the Z32 transmission).
I think if you actually drove one, you would seriously reconsider this. I had my own reservations about having such a heavy car, but I've had mine for more than a year and it's defintely a great performer. I can do just about everything I could in my turbo S14.
