I had thought that no one was reading the thread anymore, so hadn't posted in a while. The adapter plate is similar to what Wes is making, 1/4" steel with M10 screws welded to the backside. The bottom holes are countersunk and bolt to the oil pan with M8 FHCS, the oil pan has about 1/2" thread engagement. You can kind of see the detail with this pic.
As far as the oil pan CAD file goes, I can share the files that I made, but the bolt pattern is not on it. I just used the stock oil pan and transfer punched the bolt locations to the 1/4" flange.
I was having some oil starvation problems when braking hard and turning and ended up taking the oil pan off and doing some pretty major surgery to it, works perfect now. I will post a pic if anyone wants it, it now has the "wing" sections cut out at the bottom and a pretty good baffle setup.
New stuff is the p/s reservoir bracket and location. Ended up putting it in front since there was not much room left by the fuse box without having to cut anything. It is the stock reservoir with the bottom fitting cut and rotated 180 and the return line bent a little to line up better with the pump. The bracket is just some 16 ga sheetmetal bent around some pipe and welded to the reservoir to make it look nice. I have cut all of the "extra" vac line tubing off of the front pipe and cleaned up the pcv valve aluminum piece since taking the picture below, looks much better now.
Also foam filled the chassis with 3lb per cubic ft two part closed cell foam. It is really easy and got rid of a lot of the squeaks that it used to make. I highly recommend it, easy to do so long as you don't let it get on anything it shouldn't. Urethane foam can be bought online at most any fiberglass/composite supply companies.
Suspension is now mostly Powertrix, also have the SS coilovers installed. It is about 1" lower than the wore out stock springs, any lower and it scrubs going up my driveway. Wheels are MRR GT1, 18" x 8.5" f and 18" x 9.5" r with Nitto Invo as the tires.
I need to take some more recent pics of the exhaust, all 2.5" mandrel bent 304 SS with x pipe, 2 cats and 2 high flow mufflers, sounds really unique. Interior upholstery redone two tone with black leather and tan suede. Audio stuff done also.
I will take some more pics soon and post.
- Garrett
