Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Tue Nov 25, 2008 4:50 pm
Nate:
I love your response. I am very pleased with it. We are making progress so long as we keep this discussion going because I beleive it is the first step in solving the air intake heat issue the G has. Well done!
You said, "A water or water/alcohol cooling aparatus could be rigged up to extract heat in two ways. The easier, less involved method would be to create a large scale water cooling system in the same fashion that is used with PC cooling.
This involves a liquid being passed over the heat source to absorb the heat and dissipate it at a radiator (obviously a secondary radiator). Piping and a water pump will be needed and grooves in the plenum would probably yield the best heat transfer (think of a heatsink)."
Exactly what i was thinking. I forgot to add the radiator. I don't see how this set up cannot be created easily for the G with the exception of the grooves in the plenum. I agree completely in using a water alcohol system since using pure alcohol would require a compressor--additional equipment, to bring it back to a liquid state. Water in the alcohol micture reduces or eliminates the need for a compressor.
Now, the radiator which will generally be a small one can be carefully placed in the space near the front bottom end of the G where a true cold air intake is usually placed close to the bottom of the front grille to your right. I beleive this system wil fit just fine, produce more power without adding anything into the engine. In addition, the Z-tube will have to be replace with a metal Z-tube for better heat transfer.
Anyway, excellent job, Nate. That hard-working mind of yours needs a challenge all the time, eh?
