fbpem1 »
https://forums.nicoclub.com/fbpem1-u105849.html
Mon Dec 01, 2008 2:40 pm
i have been out of town for a bit so my lull in the posting department is attributed to that.
Now first off to your thing beancooker, header wrap and ceremaic coating bad, one or the other it will rub it off. watched it happen on something i tried years ago.
If your going to with a ceramic coating dont go with jethot its junk. I will ask a friend the name of the GOOD company who's coatings actually work won't fade, brown, or flake off over the years, its been tried and true and has been passed from f1 technology.
Cooler air basically the ONLY thing you can do on the stret would be a cold air box.
The dry ice thing is stupid IMO unless its a track only type of thing but then you have to pass tech with it if you have a small leak in it guess what nope not running it, seems like a water/air intercooler idea branched out for all motor, ehh to much time for minimal gain if none 5whp isn't something you can feel.
Now ram air type systems do work i have made a few for various cars, but agian minimal gains precarious filter posistion.
About the isothermal spacer, its nothing more than a plastic gasket for these cars (correct me if i'm wrong but i think i'm right), that does work although dosn't that perticular one sit between the upper and lower plenum?
what good does that do? if you do that you want it sitting on each bank in the valley for optimum gains. Forgive me but i will mention my old honda's and hondata gaskets that sit on the head and seperate the intake manifold from the head with a xx amount of clearance and those DO work. The ones i have seen installed on these cars would not really work becuase the heads are still soaking the lower plenum with heat, granted the air up untill then is "cooler" but then get blasted with the heat right at the lower plenum thus null and voiding any gain you got from that 20 minutes worth of work and how ever much money it is.
Long and short is throttle responce maybe a little, real horsepower you can feel nope sorry, nothing is going to be felt by the minimal gains that intakes get on these motors. Now the HR is a differant animal all together its a better motor through and through.
THis is experiance talking i have installed intakes, intake manifolds, spacers, blah blah blah, and i wasn't impressed just made more noise and gave the illusion of a gain. As always long winded post lots of spelling and gramical errors oh well you get the point
