i didnt have any cooling issues till i put a FMIC on and upped the boost. thats why i kept the stock s14 rad.eh? wrote:Well first off I'm not sure why you stuck with a stock radiator that's made for a 2.4 four banger for this long. The RB's are obviously bigger and the first thought that came into my head was to buy a larger radiator (either oem or afmkt). Coolant capacity FTW.
christ i wish i was still only "running warm" hahahaeh? wrote:You guys were having issues since last year september zerothread?id=137470
I remember that thread :p
id rather overheatValley wrote:good ole' fmic's. always getting in the way of that clean unadulterated radiator air and messing it up.
seriously though... ducting. or perhaps bumper mod?
zerothread?id=143660
You better get a gauge before you overheat and warp your head.NightKids2 wrote:My car runs so hot its just stupid. I dont have a gauge so I dont know exactly how hot, but now that its getting warmer outside we run it for 10-20 minutes and I burn my hand on the hood stand its so hot. Im running a Koyo radiator and dual 12 inch pullers, and its still super hot. Even my pipe comming off the intercooler is too hot to touch.
Hey, no need to hate on my POS so much! I explained my reasoning for the holes in the threadKamin wrote:
id rather overheat
u use 3 bottles of water wetter ?RB20DETodd wrote:DUCTING like kryton said, and **** that bling radiator, i know people that overheat with it, get some mans fans http://thehoffmangroup.com:16080/zirgo/, 3 bottles of watter wetter and straight water, i dont thing its freezing anymore there? I run the COPPER Koyo oem replacement radiator runs like a champ, hard to find but they come through on ebay every now and then, my 2 e fand took a **** when i drove through 2 feet of watter when i was flooding here a few weeks back, so im gonna try and squeeze 2 14'' Zirgo fans in.
Copper ownes!
http://home.satx.rr.com/nissan...t.htm
I remember that artical, with the Koyo al radiator(which i have), the altima fans worked better together then the FAL twin fans did with the Koyo + the fans are cheaper! I was having trouble with over heating before my car went into the body shop. I did buy the altima fans for $35 and a cf cooling panel for $100(found cheaper but I liked the bling factor) and I'm going to do the splash guard and make sure no air is going around the radiator and get a oil cooler.here's a pic of the cooling panelDrifterTom wrote:i had mad problems. i thought it was the radiator, so i replaced it w/aluminum. not koyo, custom and cheaper. it didn't help much., so i thought it was airflow. i added another fan, didn't help. then i took out the a/c condenser, didn't help. my last attempt was replacing the undercar splash guard and an aluminum piece for up top. low and behold it worked. i also made flashing so there were no gaps between the radiator and body. turns out i was moving air, but it was all taking the easy route and escaping. i decided to try this after reading a great write up about 240s and benefits from koyos/fans/cowls. their experiment was very scientific and was tested well. i agree with their results. i don't remember where i found it, but i am sure it was on here. i think the kids were testing it with an sr though.
