3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sun Jun 26, 2016 3:35 am
assume the level is ok? how much 'delta' do you get between the stone cold (ok, 88deg minimum PHX overnight low) bottle level and full hot when symptom?
I do not think you are on the right path, as the sensor wire if damaged would show full hot or full cold consistent. if the needle 'moves' normally that is not the issue.
yes, the correct cap is CAP, INF#21430-1P111
this is to be used at both locations. strictly speaking you could use a cap only (no spring inner seal) on the upper neck, but why bother?
more likely your issue is trapped air (incorrect coolant level), bad thermostat (THERMOSTAT- INF#21200-6P001),
bad fan clutch, no supplemental electric fan, restricted airflow thru the ac condensor or restricted flow thru the radiator itself.
also, for your climate (mild winter, hot summer) i would highly recommend a 30/70 mix of coolant to distilled water (yes--the order is listed correctly). use some redline water wetter also (surfactant)
