I might have missed this, but is either the original or replacement
thermostat OEM?There was a thread recently on the m35 subforum about an overheating issue with autozone Tstats that seemed ok in a pot of boiling water. Nissan OEM cured it.
A lower temp one will allow coolant to get to the radiator at a lower temperature, but I can't quite picture how that would affect it's top end in the long run.
But hey, a fix is a fix, right?
On
A/C function affecting the coolant temp? I see it possible for electric fan systems with dual fans whereby the A/C is one of the triggers that kicks on the secondary fan, thus helping cool the radiator as well.
I am not sure how the q45 in-cabin heat exchange box is set up, but in the 2006 M45, the refrigerant HX sits behind the coolant HX/ heater core and air would be cooled first then heated. For that system, since coolant is constantly circulating, I can see a minimal cooling effect on the coolant when the A/C compressor is asked to do its magic.
*The heater core is much smaller & also the amazing specific heat capacity of water tells me that it shouldn't be jumping degrees down.
