1991240xs wrote:Hey nismo..can I get part numbers and where you bought the two 12 inch electric fans from?..those seem to mount well on the radiator and i'm going to do the exact same setup as you-
nismod_rps13 wrote:"as for the shroud and fan, theres 4 screws that hold the shroud, one at each corner. the fan shroud is hard to take off with the radiator hoses in the way, so i just cut the shroud in half and removed the pieces. then i have more access to remove the 4 10mm nut that hold the fan to the fan clutch. then another set of 4 10mm nuts hold the fan clutch to the water pump pulley. once you remove those, put the nuts back on the pulley and tighten them up or else the pulley will come off. this is just to free up some hp and space."
you cut your fan shroud ?... but i still want mine intact... so should i still take mine apart ?... is it that hard to reach the other two bolts... the lower ones i mean...
Oh s***, you live near VIS don't you? That's crazy, did you go to Mark Keppel?nismod_rps13 wrote:ok... so how are you gonna bill me ? i can send you check or money order... send it to me at... california... i hope its not that expensive for you to send it to me...
vincent wang420 s. sefton ave. apt fmonterey park, ca 91755
Daunttless wrote:That's why most radiator flushes are considered a scam, at least 1/3 of your coolant is still sitting in your block.
