This has been on many differen't forums for the past few days. Ive read a lot of about it and what not.
This is basically went wrong with the nuclear power plant:Quote »They were going to change the fuel rods in the #3 reactor. Of course to do that you have to power down the reactor. So as they were reducing the power in the reactor they decided to do some testing to see how "slow" they could get it to run without stopping the reaction altogether.
So they started slowing down the reactor, which reduces power output, and the reactor automatic control systems are like "hey, the reactor is going too slow" so it tried to bring up the power. The controllers were like "Hm. The computer is interfering with our experiment" so they crawled behind the panel and disconnected the safety system.
So they're slowing down the reactor again, which reduces the power output, and the reactor starts cooling off a little. So the other reactor safety system reduces coolant flow to the core, thinking "hey, the core is too cool, so that must mean there is too much water in there." So the water flow goes down, and the reactor warms up again and the power output goes back up again. So the guys disconnect that automatic system too and again reduce power.
So now the reactor is slowing down, water flow is being reduced, which reduces water *pressure* in the core... as the pressure drops, suddenly it flashes to steam, which is much less able to transport heat out of the core, so the core starts heating up, and fast. But the automatic water system is disconnected now, so the heat is going up and the reaction rate is going up, which makes the heat go up faster. The controllers go "oh ****" and hit the emergency control-rod release, which should allow the control rods to free-fall into the reactor core and stop the reaction. Except that due to the now very high heat the fuel rods have expanded and the control rods only get in a little ways before they get stuck.
So the heat is going up and up, and the middle of the core starts to melt and drip into the bottom of the reactor vessel, which causes some chemical reaction and hydrogen starts being created from other mollecules that are there. Lots of it. Meanwhile the controllers hit the "emergency core flood" button, which is supposed to allow thousands of gallons of water to flow into the reactor vessel... except that the high pressure in the vessel basically keeps that water out. Some kind of spark in the vessel ignites the hydrogen and explodes the vessel, blowing the roof off the reactor building and the rest is history.
The first part of this experiment lasted a few hours... the runaway part only took about 30 seconds from the guys going "hmm... somethings not quite right" to the explosion.[/quote]More info on what the reactor core did from here
http://muller.lbl.gov/teaching....htmlQuote »The China Syndrome
The term "China Syndrome" was originally invented by someone with a strange sense of humor to describe the worst possible nuclear reactor accident. (Most people seem to think there is something worse: a reactor becoming a nuclear bomb. But, as I described above, that is not possible because the uranium is not sufficiently enriched.)
In the China Syndrome, the water that is usually being boiled by the chain reaction, suddenly leaks away. There is no water to boil. What would happen in this "loss of coolant" accident? Can you guess?
The first thing is surprising to most people: the chain reaction stops. The reason is that the cooling water is also a moderator; it slows neutrons. So when the water is gone, the neutrons are not moderated. That means that most neutrons are absorbed on U-238, which does not give a chain reaction. So the chain reaction stopped.
Interesting flub by Senator: When the Chernobyl Nuclear Reactor underwent a similar accident, the Russians announced that the chain reaction had stopped. The chairman of the Senate Intelligence Committee announced on television that this was a "blatant lie." I cringed. He was confusing the chain reaction with the decay of the remaining fission fragments. He knew the radioactivity hadn't stopped, but didn't realize that the Soviet's were being completely honest. The fact that the chain reaction had stopped was important; it meant that the level of power being produced had dropped enormously. (Remember this, if you become a Senator!)
The chain reaction stops, but there is still the "waste heat" from the fission fragments. Without the cooling water, the reactor gets hotter and hotter. The fuel finally melts. It melts through its containers and forms a puddle at the bottom of the steel reactor vessel. The fuel puddle keeps on getting hotter and hotter. The steel reactor vessel melts. The fuel falls into the ground. It keeps on getting hotter. The soil and rock melts. The fuel just keeps on going -- all the way "to China".
No, obviously it won't reach China. (Besides, China isn't on the other side of the Earth.) It won't get too far, because it spreads out, and that allows it to cool. But in doing this, it has broken through the steel vessel that is supposed to keep it from the environment. Any gases that are in the fuel pellets will escape into the atmosphere. It is these gases (and some volatile elements, such as iodine) that caused the most damage at Chernobyl.----------Incidentally, the Chernobyl power plant had a terrible design. It didn't even have a containment building, like we have in the US. If it did, there may very well have been virtually no deaths. So is it fair to think of US Nuclear Power plants in terms of Chernobyl? [/quote]Quote from someone who closeQuote »I was living about 500 miles from Chernobyl at the time, and lemme tell you something, that was some scary **** to go through even for someone living relatively far from the accident. Believe it or not, we were the last to find out what happened, or even that something did happen. The whole world knew before we did!
For days, all we heard were rumors that something unspeakable happened, and thousands of people are running for their lives. But from what? No one knew. The politicians claimed nothing happened, and international broadcasts were blocked. They were planning to keep the disaster a secret up until Germany picked up on the radiation and sounded the alarms.
I've heard horrible stories about that day. You should be able to find photos of entire fields filled with scrapped military choppers. Each was used to drop sandbags into the inferno. Nearly everyone involved in that effort has died. Take a look at this picture of a secondary school in Chernobyl, and try to imagine what those kids went through in their last moments there:[/quote]Another account:Quote » was only 2 yrs old and about 250KM from Chernobyl when it happened. Of course the soviets didnt tell anyone anything before western europe started alarming. I was sent from the city of Kharkiv (eastern Ukraine) to my grandparents countryhouse. When USSR fell apart they were showing documentaries about it and you would just see a helicopter spraying water onto the reactor and then the helicopter just falls down straight into the reactor[/quote]This is how we've tried to help.Quote »To make things worse, those idiots are setting themselves up for another disaster.
The sarcophagus is in danger of collapsing and they are dragging their feets. It is weak in many places, has ****ing holes that has allowed rain water to collect inside. The structure is so weak, a moderate earthquake will knock it down.
The US, G-7 countries pledged their support and as a start contributed 300+ million dollars to build a new sarcophagus. Hell Ukraine/Russia wouldn't have had to spend a single dime, the international community said they would pay for the entire thing. This was in 1997-1998.
Environment Minister DISMISSED THE ****ING IDEA and said no decision would be made until THREE YEARS LATER
and here we are 6 years later, after we gave them several 100 millions of dollars, they are still dragging their ****ing feet. Nothing has gotten accomplish other than constantly revising ideas.[/quote]
