DO YOU OWN OR HAVE YOU DRIVEN A VERT?Red coupe wrote:I think the vert is heavier on a less structurally sound chassis, its a cool car but if your trying to make a track car it might not be the best start. not to say it cant be made to handle well but a coupe or hatchback would always be a better start for pure performance concerns....
afracer wrote:My convertible feels like it handles better than my 180SX did with the exact same suspension, but I can definitely feel the extra weight. I'd have to take it back to Japan on some of the mountain roads to really tell the difference but the first time I drove my convertible it felt a lot tighter than my 180SX ever did. I've got a Tanabe Sustec suspension with pillow ball mounts all around, 180SX sway bars, and pillow adjustable tension rods and rear suspension too. I plan on installing a strut bar, power brace, roll bar, and any more chassis stiffening parts as well as coupe doors and possibly a few other lighter weight items. In the end I think it'll handle pretty awesome and I would gladly challenge a coupe or hatch with similar mods to some spirited corner carving. It's more about how it's all set up and working rather than a couple pounds and type of chassis. Coupled with a good driver a convertible could easily take a hardtop... you guys sweat the details too much!
I agree that mine flexes less when jacked up, but that doesn't make it stiffer, eveything shakes on every bump.. I'm not sure what your point is about the mustang or the camaro, they are similarly reinforced to the 240sx and still flexier than the hardtops.audtatious wrote:Dude, did you read? The 'verts do have additional bracing from the factory. Per they "jack test", the flex LESS than the coupes do. This is not a 'vert mustang or camaro.....
Then what does it make it?top_secret wrote:I agree that mine flexes less when jacked up, but that doesn't make it stiffer
And their you have it....I dont think any one here is trying to say that a vert cant handle even the title of the thread is that they handle better.If it handles better then a coupe I would expect to see a better lap time.Again s13 verts are awsome cars, and I would love to own one, but mod for mod they will not yeild more preformance then a base hatch or coupe.nissanconvert wrote:out of boredom and curiosity, i propose that the convertible should handle ( with proper suspension setup) better then a coupe/ hb.
Yes, I read very well, thank you. I also own a 240 convertible (and have owned a coupe). And the one thing I can say with 100% knowledge is that a 'vert will always be a more flexible chassis when compared to a coupe. You can't replace lopping the roof off a car. The closest you can get to that is putting in a 6 or (better) 8 point roll cage with the strut towers all connected to one another.audtatious wrote:Dude, did you read? The 'verts do have additional bracing from the factory. Per "jack tests", they flex LESS than the coupes do.
