nissanconvert wrote:Many well performing cars have no roof at all with good lower bracing, dodge viper, ariel atom, shelby cobra, many brittish roadsters, and i don't recall F-1 cars having much aside from a carbon fiber bubble or open air.
with the new version of the viper that came out as a vert, they had to make the coupe from it to build the competition coupes, they didnt have a viper with a roof to work with
f1 cars have a tiny little opening, ever tried to sit in one? if you can fit in it your lucky, you wont be able to move regardless...even so the rest is a solid sheet of carbon fiber, REAL carbon fiber, not the stuff everyone puts on their cars, ever try to take two people on each end of a sheet of sheetmetal and pull on each end, to try and get it to split simply by pulling on either end? yeah not happening, real CF is a lot stronger than that
same goes for the le mans prototypes and everything, the cars would be slower from having a bubble canopy than they are from that tiny little opening
skidpad numbers have so many variables it wouldnt prove much of anything
im sure its like a lot of things we try so hard to do that really make no difference, will the average person be able to tell the difference just driving around on the street? ...probably not
by the time you got the vert track ready enough itd be so far from stock it wouldnt really prove anything aside from that one car, nobody else would see the same results with their verts
