mentordrift »
https://forums.nicoclub.com/mentordrift-u39083.html
Tue Aug 19, 2008 5:07 pm
I'm not entirely sure what's happening right now with my RB25 in my S14, but it seems like I am suffering either a HUGE non-detectable boost leak, my fuel pump is taking a major $h!t on me, or I have a faulty ignition switch.
What happens is the car will run fine earlier in the day, like around 7 am, and will run fine when colder in the operating temperatures. But when ran for a longer amount of time, usually around 15-20 minutes, it will unexpectedly lose power - as in; pushing on the gas pedal, no response.
A flick of the key from off to back on will correct this - without having to turn the key to "start" - like if you turned it "off" then back "on"
Then, the car will not boost higher than around 1-2 psi, it will studder and hesistate severely when trying to boost any higher than that.Then suddenly, the car will act fine again, boosting happily to 10-11 psi, no breakups in power, no nothing.
At first I thought my MAF sensor was going bad, but the symptoms aren't consistent enough, and I can rev the engine well past 3,000 rpms when not getting into boost WHEN the problems occur. When the car isn't having issues, the car rev's happy-as-a-clam
Then I thought - maybe a boost leak? I checked all of my intercooler piping, and gave a quick visual to the vaccuum lines around the intake manifold, but didn't spray them with soapy water or use a compressor to test YETBUT this doesn't make sense either because I will be able to hit boost, and then suddenly not, and then again, be able to hit boost again.
I have been checking things off as I go along:-Ignitor is good-Coil packs are good-Compression check at engine install was all positive with zero leakdown-I haven't checked the plugs yet, because I work just long enough to have no time except on weekends.-Fuse under the hood for ignition is good, also new - but I did have electric fans hooked up to it at one point; also just prior to having these problems did I remove them and connect them elsewhere they are FAL 220's on a Mishimoto radiator.-Fuel injectors are all firing as they should, when the engine is turned by hand they do what they need to do, blah blah.
I have a Nissan Quest alternator and a optima redtop battery, but the battery holds a solid 13.9-14.1 volts even when power cuts out. The battery cables do not have any frays or tears that are grounding the positive side either.
As for the possible boost leak or turbo problems, the only places I haven't really checked good are the BOV (non-recirculated turboXS H-RFL), most vaccuum lines at the firewall, and the boost controller/wastegate area - only because those seem like the car would barely run at all if that were the case.-Would a good check be to replace the h-rfl with the factory recirc. valve, and see if it cures the problem?-Is the turbo possible damaged somehow? Some kind of debris, or SOMETHING that is causing intermitent....****ting on?
As for my fuel pump...I am prepared for flaming on this one:It's a stock S14 fuel pump, but it is under 2 years old. I know that I shouldn't be running it, even at all - but is it possible that the fuel pump is actually starting to get lazy and I am having fuel starvation problems where there is very little fuel pressure?
Then the ignition switch: I have always had a blinking airbag light in my car, even before the RB swap took place - and I am pretty sure that some backwoods mechanic replaced that switch, because it just doesn't look right - the cylinder is....too out of place? Could a faulty ignition switch be sending a bad signal to the ECU and confusing the hell out of the car?
I know that this is ridiculously long, but I just spent the last few hours searching the forums for similar symptoms that others have had - and I have a combination of them!At this point, I want to take this slowly, bounce my ideas off of the guys (and girls?) on here, and just figure this out once and for all!
