krazydriver wrote:As long as the BOV is venting it's probably not compressor surger, more likely it's the BOV fluttering. If it's adjustable you just need to tighten it up.
Incorrect.
To the OP, it is indeed compressor surge. The ebay bov you have does not realease easily enough at very low boost levels, most likely because it is adjusted too tight. No matter what bov you have and depending on how much boost you are running, there will almost always be a little bit of compressor surge, it is normal, and it is nothing to worry about. I would say the HKS will still surge lightly, but it is a much better bov for your use.
