IanS »
https://forums.nicoclub.com/ians-u23642.html
Thu Apr 12, 2007 3:24 pm
a little bit of compressor surge isnt the end of the world, as long as it is not excesive it wont harm anything, the seals and bearings, (in journal bearing turbos especialy), will wear out eventualy, and the turbos previos life in Japan will have a lot to do with it, like what kind of oil was used, was the engine warmed up befor hard driving, and was it cooled down after, all these things will effect the lifespan. and even if the seals do go, a full bearing and seal kit plus the cost of bead blasting the wheels and balancing them is only about $125, or if you dont want to rebuild it yourself it usualy costs about $450, take good care of your turbo and it will reward you with lots of boost.
