completely STOCK SR20DET engine with only 3" straight pipe..ok for 12PSI???
91nissantwo40sx
the engine is completely stock no changes at all. only a 3" exhaust all the way back with a 4 inch glass pack muffler ( it has no catalitic converter on it) The exhaust is a strait pipe (no resonato) I also have a boost gauge and engine is currently running at 7PSI
I was wondering if i could boost up at 12PSI without changing anyhting?
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
search. that are alot of threads about this.
FMIC Boost controllerwill be needed!
drftsx
Car: 90 240sx(sr)
+ fuel pump. i think youll be leaning your car out.
91nissantwo40sx
so pick a Walbro 255 fuel pump first? then im good?
usdm_180sx
Car: 1993 Nissan 240SX base S13
Did you read the posts? Easiest way to do this, and you will need ALL of these:
1. fuel pump2. fmic (or s15 smic)3. hks actuator
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
SMICs heatsoak very easily above 9 or 10 PSI
mowedS14
Car: 95 240SX 91 Honda CRX
usdm_180sx
mowedS14 wrote:Cheap and rather large -http://cgi.ebay.com/ebaymotors...wItem
The ONLY thing guaranteed on fleabay intercoolers is S H I T T Y FITMENT. Get a Greddy M-Spec for $400
91nissantwo40sx
greddy m spec should fit in no problem right? what about battery? id prefer to just buy a smaller battery but which one should i get? any recomendations?
91nissantwo40sx
will it fit on the S13 no problem? btw i have a Canadian 240sx so i dont know if the front will be the same as the ones in the US.
usdm_180sx
Yeah spec m shouldfit perfectly. the piping is nice. Get this battery: http://phase2motorsports.store....html
jessetang
Car: 1995 240sx
You will at least need a smaller battery for a FMIC, or battery relocation since it goes through the stock battery location to the intake manifold. Smaller battery works just fine (I use a Miata battery).
You are asking questions without looking at your engine bay. There are simple, basic knowledge for most FR turbo owners.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i use and odyssey pc680 battery i got off ebay, its a dry cell so it is nice and it fits perfectly.
240trackjunkie
Car: 1990 Nissan 240sx
I've been running a completely stock redtop at 11-12psi for almost 2yrs now, problem free. I think you'll be fine, just don't go above 12.
Modified by 240trackjunkie at 2:51 PM 10/31/2007
IanS
240trackjunkie wrote:I've been running a completely stock redtop at 11-12psi for almost 2yrs now, problem free. I think you'll be fine, just don't go above 12.
You should go be friends with this guy, I think you would get a long great
J/K
How often do you heatsoak in the hot TX weather, and are you running a stock fuel pump?
240trackjunkie
Haha, thanks. Looks like I have a twin brother lol.
Yes, I do have a Walbro pump, 3" exhaust, and HKS bov. So it's really not completely stock but none of that should effect it's ability to tolerate boost.
Actually I've never heatsoaked my smic that I know of. Even after beating on it for a good 15-20min, the intercooler is still cool to the touch (I've actually gotten out of the car to check it lol). Most of my time online is spent reading thread after thread on sr20's. It is well known that stock boost is 7psi but my front clip came with the stock ebc solenoid that brings that up to 11-12. I think that is what the stock Silvia's and 180sx's run in Japan? It seems to me that it would be ok to run a stock engine at that boost level since that's what it was originally designed for?
Modified by 240trackjunkie at 5:17 PM 10/31/2007
Modified by 240trackjunkie at 5:18 PM 10/31/2007
IanS
when I had my sidemount that thing would heat soak really bad even at 10 PSI. If it was hot out and I ripped through the gears 2 or 3 times repeatedly all of a sudden I would loose all power, hasnt happened once with my FMIC.
240trackjunkie
Individual results may vary, I guess.
stuntinSR20coupe
Car: 1990 240SX SR20DET coupe (coupe love!)
yeah for sure i run 11-12 lbs everyday so far on my nearly stock SR. i have just a greddy front mount and dp and hks bov for approx. 6-7 months no problem.
godzilla34
Car: nissan 240sx sr
i kno its an old post and not to revive it. but the serching does help in this field. on a stock motor i wouldnt push the turbo past 10 psi, depending on the turbo and intercooler, is depending on heatsoak. not all turbos/i/c's are the same. if you get to hot detonation occurs which ='s bad mojo for the innards
(sorry bout spelling been up for a few days workn, finaly got a chance to chillax)
