nope. F3/M63 plug into each other on the s14 car. one is the male side, one is the female side. basically the concept is to leave the male side in the car and cut off the female side from the KA engine harness. then merge that side into your RB harness and done. more than 20 wires definitely.FriedEGs wrote:thanks for the reply.... i'm assuming the F3 is the plug from the rb harness, and m63 is from the car (s14)? Also, how many wires are we talking about changing?! 8-10, or more than 20?!
who said anything about matching colors. you repin to match functions... tach, speed, start, air regulator, etc... Thats why you need to look at the rb25 harness diagram and f3 pinout.stiergott wrote:ok time out. your tellin me the power plug from the rb will plug into the power plug on the s14? your not serious(?). i have looked at a pin-out of the f3 rb and the colors dont match the s14 at all, so you cant simply match the colors. it is easy, easier than swaping into a 13, but its not like s13 sr to s13.
If you look where your s14 ecu is, the stock location in the passenger side kickpanel. Theres a f3/m64 plug thats located on the metal part of the wall. its plugged into another panel with a swinging hinge that locks in the harness. You'll know it because it has about 36ish wires coming from it. It is also next 2, 2 fuses the ign and... something else for the stock s14 stuff.300Plus.net wrote:Ive got both FSM and I'm about to start tackling the unkown areas in my head. But I would love any extra help, so anyone who has links or anything please PM me or post here. I have to locate a diagram of which plug is which.
Corrections made, Thanks HotWIRED.HotWIRED wrote:I didn't check them all, just the power and fuel, tach, VSS pinouts. I would change these, RB pin (12) to KA pin (1) << IGN power, also the grey wire for the injectors if you have the 1ST gen RB25DET. RB pin (4) and pin (24) to KA pin (17) <<ECCS power relay>>. The KA pin (18) is just power to various sensors. If you have the '97-'98 KA service manual check pages EC-97 and EC-212 for the IGN SW diagrams. Also check page EC-240 for the ECCS relay diagram.
