Complete wiring for RB25det into 95 S14
Bluefire
Ok I've looked over my notes and here is what I have to say.
First: your numbering of the pins are slightly confusing you should show how you numbered them.
Second: You have a lot of useless stuff listed that is not needed (It might just end up confusing people) ie... when troubleshooting people following this quide will have twice as many wires to go through.
third: The following pins are wrong, have an error, or are missing (6, 10 , 11, 15, 20, 24
fourth: The following pins are questionable as I used different wires to hook them up (12, 21)
last: These corrections are referenced from my personal wiring guide which was used to wire up an RB25det in an s14. The car ran perfectly with no ecu codes, so hopefully these corrections are right. But don't hold me to them.
-Bluefire
ehacker01
Car: 1995 240sx
the number is looking at the back side of the harness(wires coming out). What did you use for pins 24 & 20. The rest of the wiper stuff I don't really care about because I just ran those parallel.
As far as those pins being wrong, I got all of that from the diagram but I'll look at it again.
Maybe a better question is how did you hook up the fuel relay and eccs relay if not using the f3/m63 plug
300Plus
Car: 1995 S14 w/ Rb25det Series II
When you say you ran the Wipers parrellel you mean you just hard wired them with out going through the ecu? or what? But glad to see we are def making progress on the M63/F3 Guide
ehacker01
Car: 1995 240sx
Parallell meaning I left them attatched to the KA m63/f3 plug and removed them from the ka harness and ran them along side the rb harness
300Plus
So I assume the RB harness doesn't have the wiper controls? I thought it was the same. So you just ran the wires from the M63/F3 connection to the wiper motor it self?
ehacker01
Car: 1995 240sx
The RB harness does have wiper controls but basically yes just look at the pinout from the ka and trace all of wash/wiper wires back to their plug and then remove them (with wires) from the ka harness and add it to the rb harness. I could have used the ones from the rb but its just more wires that could get mixed up so I figured leave them alone. I left them on the ka f3/m63 and swapped the RB wires into the KA f3/m are swapping all the wires over to the ka f3 and leaving the ka wiper wires there.
300Plus
So are you hoping to get everything wired up this weekend?
ehacker01
Car: 1995 240sx
I think I've got the wiring done but had a horrible work day today and couldn't get the motor in.
1. I cracked 2 pilot bushings trying to install them
2. Comp. Clutch sent me the z32 throwout instead of the z31.
3. The splines on the disc are too narrow and the valleys are not deep enough and won't fit the shaft
Not a happy camper today....hopefully it will run tommorrow.
Anybody have any idea how much hp a High pressure, pressure plate and a stock disk will hold?
300Plus
any updates?
ehacker01
Car: 1995 240sx
Finally got everything ready to start the motor but couldn't find my circuit tester so I will try it in the morning. I still have to make the throttle cable brackets, add coolant, fill transmission, etc.
I'll keep you updated
ehacker01
Car: 1995 240sx
Well, it runs. no codes or nothin. I haven't checked the diagnostic ports or a/c yet but everything else works. I'll repost that file later tonight with what I hooked everything up to on the f3 plug.
300Plus
Sounds good. I'm waiting on my clutch replacement discs before i put her in for the last time, but when I get then in I'll throw the motor in and give a second testimony to the guide's accuracy.
ehacker01
Car: 1995 240sx
Well here is how I wired mine. It runs fine but has not been roadtested as I am still waiting on my driveshaft.
Modified by ehacker01 at 8:54 PM 8/27/2005
Modified by ehacker01 at 5:39 PM 9/1/2005
Modified by ehacker01 at 6:19 PM 9/19/2005
Reignman
Car: 1995 240SX
Does anyone know if this is accurate?
ehacker01
Car: 1995 240sx
Reignman wrote:Does anyone know if this is accurate?
I do. It starts right up.
Driveshaft should be back by friday so I'll have more updates soon.
300Plus
ehacker01 Jon was trying to get ahold of you did he?
ehacker01
Car: 1995 240sx
No, I don't think so. Who is Jon?
ehacker01
Car: 1995 240sx
Well, I drove the car yesterdy and everything worked fine. Hooked up the VSS and the speedo works. so that has been updated on the sheet. The only things still in question are the diagnostics stuff and the A/C
smokeybear
Car: 1995 240sx
great info there guys. the only worries i have about mine (still far off but reading about it none the less) is the wiring. im completely compitent in my removing the motor, installing new, etc etc, but im scared of wiring. id love to have a perfect guide to how to install it and id probably pay money for it as long as everything was ok and my year (i have a 95 240) thanks for the info.
eh?
Both wiring issues are now covered. USe that guide for the F3-M63 wiring and search for the RB lower harness wiring. IF you're not confident, up on your right there's an ad for engine swap wiring.
ehacker01
Car: 1995 240sx
check out http://www.racebread.com. They have instructions for the lower harness on the "files" page. As far as the motor harness, what I posted is everything you really need.
ehacker01
Car: 1995 240sx
Just an update. I have tested the consult port (diagnostics) and it is working perfect. So the only thing that has not been tested thus far is the A/C switch. the Pinout's notes have been update with this info.
Dnight07
Car: s14
hi guys I'm totally a newbie , i've been doing research here and all the threads that i can find in Google, i got screwed pretty bad with my swap but that's another story, the harness that i have is cut i just bought another but its some what different I'm wondering if the good harness can still be used with my rb25det here are the differences : the good has more connectors than the bad like in this pic: i have the pin outs and the good seem to be a series 1 so i'm guessing since my bad harness half is missing there is no way of telling is there?
[IMG]<a href="http://www.mywackospace.com"><img src="" alt="MySpace Editor" /></a>[/IMG]
Dnight07
Car: s14
guess my pics didn't show up but if any one interested in helping me with this issue please e-mail me and i will send pics.. thanks.
*REDACTED*
Reason: EDITED
noob smacker
Car: 95 s14, kouki convert, RB20DE-T
i have one question, will this process work with the rb20... icant seem to find any info on ether harness... im not doing the wiring i`ll be installing a new set of coilovers for the guys sr s13.. he broke his arm and cant do it so i proposed a trade... haha thats a broke @$$ drifter for you
