Darius »
https://forums.nicoclub.com/darius-u5470.html
Mon Sep 14, 2009 3:25 am
Ahhh this thread brings back repressed memories.
I completely agree that preparation is key on any metal head gasket (MHG). HOWEVER, the smoothness recommended by Cometic was something that could not be achieved by simply decking the block and head. A near mirror finish is required to get the 50A (?) smoothness, which takes additional polishing. Ludicrous when you can get a gasket for the same price that doesn't require that level of finish.
On my first go around, I only decked the head and cleaned the block up the best I could with extremely fine grit sand paper and it leaked upon startup. My bad! The second go around, I had both surfaces milled and the gasket still seeped. Cometic's bad! I didn't see evidence of any coolant in the oil, but it definitely seeped down the side of the block. I am on the third gasket and this one has sealed, for now. I don't want to jinx it.
There are other gaskets out there that are more forgiving. Cosworth, HKS, etc. The problem with the Cometic gasket is that they use Viton to coat the metal layers. Viton is a very smooth, slick material that has higher temp resistance than EPDM, but it is an inherently troublesome gasket material. This is not only for engine applications, but for large industrial air supply applications too. Contractors always complain when we specify them install Viton gaskets in air piping because they always have to go back and reseat the gaskets.
I'm not a huge fan of copper spray since it is a bit of a band-aid fix IMHO.
If I ever have to pull the head, I'm reinstalling a Cosworth gasket.
