rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Tue Nov 17, 2009 5:04 pm
I had my motor built 5 yrs ago, block and head both decked... Used a cometic and never had an oil or coolant leak between the 2... But then a few yrs after the build, one day i leave the driveway and my water temps went SKY high and very quickly, go back home and to find out i was low on coolant.. But never saw any leaks..Few weeks go by and the same thing happens every so often, i would leave the house and within 3 miles the temps went sky high as if i had air pockets.. Go back home and find out im low on coolant AGAIN..!!! This went on and on for months and i was clueless to know why i kept loosing coolant, yet i had no leaks and kept bleeding the system, draining it, filling it back up and even taking it to a mechanic to have them "properly" drain and flush the system... And a few weeks again the same problem...!!!
Just last week i ran into a bad spark plug, went to take it out and it seized in the head and snapped while trying to remove it... So i had to remove the head to have the machine shop remove the bottom side of that plug that was still in the head... Just to find that when i pulled the head off and inspected it, i notcied that the # 3 cylinder was so much cleaner than the other 3 sides.. and to my eyes i noticed that the headgasket had damage to it on the # 3 exhaust side... some of the black material was missing and thats when the machine shop guy said, thats where the coolant was jumping over into the combustion chamber and burning away, which explains why that cylinder so clean and thats why i was low on coolant every so often and why my spark plug seized due to coolant getting into the threading...So now ive got my head back, spark plug removed, vacuum tested the valves and they came out ok, and he lightly shaved the head to remove the left over cometic hg impression...
So, just a nice little story for you guys about the cometic... not sure what caused that hg failure but it did and only in that little spot..
