codyace »
https://forums.nicoclub.com/codyace-u28194.html
Mon Feb 04, 2008 5:58 am
If you're using ARP studs
Lube the ARP studs with ARP (or similar moly lube) on both threaded areas. Put the studs in by hand. Maybe use a small allen to gently snug, not tighten, them just to ensure they are all in..
Apply a bead of sillicone on the timing chain cover area. You can touch the actual block with it, but go no more than 1/4 past the timing chain cover. Use Permetex Ultra Gray, and none of that sloppy looking orange or blue stuff.
Put the gasket on. Do not use any sillicone or copper spray.
Again, spread a thin layer of RTV in the front timing area like you did before.
Put the head on
Dip the ARP washers in a oil, and then put the ARP washers on the studs(where they pop through) Yuo just need a slight little coating on them.
moly Lube the inner threads of each ARP nut, and then install them onto the studs. Use a normal wratchet to get them all on to start. Don't tighten, just snug them to the head.
Then, using a proper torque wrench (click type, none of that digital or bendy scale crap) torque them all down in FSM sequence (just number sequence, not in torque amounts) in incriments of 10 ft lbs. Do this until you get all the way up to 80, where you then stop, where you will then goto 85 in a 5 lb increment.
To easy.
FWIW: Yes you can technically reuse MLS gaskets. You can also reuse ARP hardware.
