bunda4th wrote:You can actually take the top knob off. Use a 14mm wrench to remove it. I actually removed my driver size since it somehow bent...So I just use the passenger knob when I need to adjust the driver side lol. I also had the gap and the best way to actually fix it is to jack up your car and loosen the perches because when you tighten the top bolt you might need to redo the pre-load. I notice when I redid the pre-load thinking that was the problem I notice the top bolt needed to be re-tighten even more than before. But if the sound is gone I guess you are safe.
Good to know; I periodically tighten both front bolts, now, and an impact gun might be a more "permanent" fix if the noise keeps coming back.
I haven't attempted to do the rears yet, because the bolt wasn't where I thought it would be (by the knob, way up in the wheel well). I think it's closer to the wheel, so I'll have to remove it to take care of it.
Worst-case scenario is that I have to unbolt the actual shock and then reattach everything... giving more opportunity for something to be too loose. Sort of defeats the purpose.
