No, I do have the Tein SS coilovers.PhEnoM78 wrote:loop has the springs NOT the coils noone has tested the Tein here yet hmm ima go call them lol
Bunda, is that the problem? My passenger-side coilover makes a loud clunking, almost a popping noise whenever I go over sufficiently-big bumps (and sometimes it reverberates after large bumps). I have time enough to prop the car up and undo the top three bolts and re-mount them if that's what you're talking about...bunda4th wrote:I have problems with my BC but I rarely get on here. Driver side spring spins when I turn the wheel so it makes a loud clunk/pop sound. I can fix it but I haven't had time to take the coilover off the car and reassemble the top-hat since that is not sitting correctly. Other then that no other problems.
The spring will move when turning your wheels. That is how it is designed.bunda4th wrote:I have problems with my BC but I rarely get on here. Driver side spring spins when I turn the wheel so it makes a loud clunk/pop sound.
Answered in PM.HelloImJarred wrote:hey flight could you PM me if they are compatiable for the 2.5S cuz i own a 2.5S and am looking at getting the Teins if they are compatible.. any info would be helpful!
thanks in advance bro
this happened to me with all four coilovers, very annoying and i was about to return them but i told my shop about it and they fixed the problem, something was loose or whatever. i noticed most ppl have installed their coilovers themselves maybe you should just go to an established and experienced shop just to make sure everything is perfect. After they fixed that loose object and i adjusted my ride a little smoother ive had no complaints and it feels smoother than my eibachs did.IBCoupe wrote:I'm getting some pretty distinctive clunking on the fronts passenger-side assembly, and I can't figure out where it's coming from. Not sure if it's the coilover or if something has come loose. Tried tightening things up yesterday, but no change.
Who installed it in the first place? Having all 4 doing that is a bad install from the start.coderedk wrote:this happened to me with all four coilovers, very annoying and i was about to return them but i told my shop about it and they fixed the problem, something was loose or whatever. i noticed most ppl have installed their coilovers themselves maybe you should just go to an established and experienced shop just to make sure everything is perfect. After they fixed that loose object and i adjusted my ride a little smoother ive had no complaints and it feels smoother than my eibachs did.
my friend at his shop, and yea he had never dealt with the pillow ball coilovers maybe thats why? idk whatever he fixed itLoop wrote:Who installed it in the first place? Having all 4 doing that is a bad install from the start.coderedk wrote:this happened to me with all four coilovers, very annoying and i was about to return them but i told my shop about it and they fixed the problem, something was loose or whatever. i noticed most ppl have installed their coilovers themselves maybe you should just go to an established and experienced shop just to make sure everything is perfect. After they fixed that loose object and i adjusted my ride a little smoother ive had no complaints and it feels smoother than my eibachs did.
For those who have issues, I would check the top strut bolt, pillowball bolts(top and bottom), lowering mounting points, sway bars, and endlinks. Make sure they are all tight(torque correctly). Also preload them correctly(3-5mm).
I've got to change my oil. Maybe I'll take it to the shop and have them tighten up everything again. Thanks for the advice!Loop wrote:For those who have issues, I would check the top strut bolt, pillowball bolts(top and bottom), lowering mounting points, sway bars, and endlinks. Make sure they are all tight(torque correctly). Also preload them correctly(3-5mm).
Can we have the answer to that question (if they work for the 2.5) on the forums as well?Loop wrote:The spring will move when turning your wheels. That is how it is designed.bunda4th wrote:I have problems with my BC but I rarely get on here. Driver side spring spins when I turn the wheel so it makes a loud clunk/pop sound.
