Coilover Question
Nategreat923
Car: 1992 240sx "Sil-Vert"
Im picking up some Stance basics, and I was wondering, does S13 coils fit on verts? Thanks for the answer
110octane
Car: VQ35DE powered 240SX Convertible *SOLD*
SR20DET powered S14
Yes, they are the same. I think this has been covered already.....guys?
However, for you my fine sir I will answer. Some "clearancing" in the rear behind the seat cushion back may need to be done. I had to take about a 1" square area out of the metal chassis support frame that has been welded into the rear of all convertibles. You'll understand once you have it apart. If not, drop me a line and I can walk you through it.
Good Luck. Happy topless motoring!
94_240sx
Car: 94_240SX
110octane wrote:However, for you my fine sir I will answer. Some "clearancing" in the rear behind the seat cushion back may need to be done. I had to take about a 1" square area out of the metal chassis support frame that has been welded into the rear of all convertibles.
I made a mistake on this one. If I can do it all over again, I would cut and modify the knob, so I don't have to cut the brace. Just use a Dremel and cut rear knob and grind the top, so that little adjust knob/cap will fit.
Nategreat923
I knew it had been covered many times haha, I searched but found nothing... Thanks for the advice! Im picking up some Stance Basics for retarded cheap, so I didnt want to mess up the install
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
94_240sx wrote:I made a mistake on this one. If I can do it all over again, I would cut and modify the knob, so I don't have to cut the brace. Just use a Dremel and cut rear knob and grind the top, so that little adjust knob/cap will fit.
What's your reasoning behind this?
I found it easier - well, also necessary for my Endura Tech coilovers - to notch the brace to fit. I still need to drop the coilovers to adjust the valving though because I have a removable adjustment knob.
As long as you don't have any sharp corners, any loss of structural rigidity will be minimal. Remember, stress collects at corners and leads to fatigue and cracking at those points. So if you're going to notch the brace, make everything nice and round.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Nate, this was linked in the FAQ. I'll just leave it here for you
zerothread/200644
94_240sx
Car: 94_240SX
There was not much space, so I cound't make clean cut. Besides, I did in the middle of summer in my garage, and it wasn't fun at all. Just get a Dremel, cut the knob, and modify the tip, so dial would fit and that's about it.
On driver's side, you will have to break the bottom of seatbelt housing a little bit to make it fit otherwise knob will hit. You don't have to do this on passenger side though. I didn't have to go through all this trouble if I just modified the knob.
Nategreat923
Ahhh, wow I didnt think about looking there for the info, thanks!
Is it just me, or does the pictures not work when clicking the attachments?Because I really wanted to see the stance one
240lookis
Car: 1990 240sx hatch
aren't s13 verts still s13's
haha. i know nothing about this to tell you the truth but you obviously got your answer.
