onosqv
Q to the V
'92 240sx Vert & '91 300zx TT
bewbews.com
8-7-2002
| « Re: Eibach Sportline springs (cheap_sticker05) | 2:30 PM 9/29/2006 |
they'll fit just fine. those (except vert) ads are for the most part, incorrect.I would actually recommend the rsr springs tho, those go low & seem to perform better... I had agx + sportlines on my coupe. My friend had agx + rsr on his fastback. The combo of agx + rsr seemed better. The lowering seemed better too (sportline typically makes the rear look lower than the front). The sportline + agx are fine tho, for most driving - I suggest running the agx @ 3/4 & 6/8 to match the springs tho. Rides pretty good.
brokeAs240sx is the coolest guy ever.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: Eibach Sportline springs (cheap_sticker05) | 2:33 PM 9/29/2006 |
| Quote, originally posted by cheap_sticker05 » | Does anyone know why the Eibach sportline springs do not fit on a vert? If they don't does anyone have advice on which springs are the lowest and fit? Thanks, Rich- |
I did a lot of research on springs. Most will say 'Exclude Convertible' in their catalogs, but just ignore it. All springs for 240sx will fit with no problem. You can expect slight more drop because vert weighs bit more. Sportline drops more compare to other springs, and it's progressive, not linear. I think Tanabe GF210 is best bang for the buck for 240 vert. You have other choices like S-Tech, RSR, Prokit, Sportline... but I like GF210. Check out attwater's car. He has GF210+KYB.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: Eibach Sportline springs (brokeAs240sx) | 2:35 PM 9/29/2006 |
As far as I know, you can go lower with GF210 than RSR. Yeah, RSR is a good spring, but GF210 is cheaper like $156 shipped.
madcowvert
miami fl
1-5-2006
| « Re: Eibach Sportline springs (brokeAs240sx) | 2:36 PM 9/29/2006 |
its not that they dont fit its that the car would go lower then what they say because the convertible springs are taller them regular coupes and fast backs due to the fact that the vert weighs so much more....
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: Eibach Sportline springs (madcowvert) | 2:37 PM 9/29/2006 |
| Quote, originally posted by madcowvert » | | its not that they dont fit its that the car would go lower then what they say because the convertible springs are taller them regular coupes and fast backs due to the fact that the vert weighs so much more.... |
I checked Nissan parts catalog and all sturut part numbers are same, but vert has different part number for the spring.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: Eibach Sportline springs (94_240sx) | 2:38 PM 9/29/2006 |
This is attwater's car. Nice drop and stance...
Modified by 94_240sx at 6:06 AM 9/30/2006
Attachment: vert.jpg (128628 bytes, downloaded 700 times)
Eikon
Super Moderator
'92 240sx 'vert with RB20
hidden
4-24-2004
| « Re: Eibach Sportline springs (94_240sx) | 4:31 PM 9/29/2006 |
Nice informative thread you guys.. I'm going to change the title on it to read (Info about springs for 'verts) and link it to the sticky thread! Nice job! btw.. I should have a set of KYB AGX shocks with Eibach Sportline springs next week.. I'll update with pics to show results.
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
 Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
onosqv
Q to the V
bewbews.com
8-7-2002
| « Re: Eibach Sportline springs (Eikon) | 4:52 PM 9/29/2006 |
While we are at it, I'll add some coilover info, hahahaha.For coilovers, in my case KTS coilovers from SPLParts, you may need to bend/hack/saw part of the rear firewall/rear seatbelt supports. The adjustment knobs on these coilovers get in the way when installing them. Other than that, a direct fit.  *and if you have a setup like Tanabe Seven w/ the TEAS (electronic dampening control), you will have to cut A LOT more.
cheap_sticker05
1994 Nissan 240sx VERT! 1995 240sx
Orlando FL
3-30-2005
Thanks for all the info. Am I missing something though? The gf210 say they lower 1.5 fr and 1.0 rr. The Eibach sportlines say 2.2 fr and 2.1 rr. Does anyone know if the sportlines are in fact a lot lower?
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (cheap_sticker05) | 9:14 PM 9/29/2006 |
| Quote, originally posted by cheap_sticker05 » | Thanks for all the info. Am I missing something though? The gf210 say they lower 1.5 fr and 1.0 rr. The Eibach sportlines say 2.2 fr and 2.1 rr. Does anyone know if the sportlines are in fact a lot lower? |
If you want more drop, go with Sportline. If you want decent drop and performance, go with GF210. If you want performance, go with RSR. If you don't want any headache, Nismo S-Tune is also a good choice. Sportline is progressive, so I've heard that your car becomes unpredictable when hard turn. Spring rates become different right and left due to weight shift. On the other hand, linear sping rates will remain same, so handling should be better. Sportlines gives more drop, it means you will have more chance blowing up your shocks. Stock shocks sometimes blow up if you use Sportlines. One of S14 guys installed Sportlines, front drop was too much, so he swapped just front springs with Prokits and they raised front little bit. Drops you mentioned are based on hatchbacks and coupes, not on verts. Eikon, RB weighs more, so I wonder how you car will look like after the installation especially front. If I were you, I would go with coilovers. That way, you can have more adjustbility. brokeAs240sx, I'm going to install Stance coilovers in the back tomorrow along with SPL RUCAs. Front ones already went on with no problem. I didn't know I have to bend/hack/saw... Dang... I'll see if I can get away with Satnce coilovers. I'll try to take some pictures, so you guys can see. I've talked to Kuah w/SPL and Rob, Eric & Eric w/Stance and they had no idea about coilover installation on a vert. None of them seen their coilovers on a vert in person or worked on it. Speaking on RUCAs, do this if you lower your vert. As far as I know, this is what attwater had to do too. http://www.240sx.org/links/ins....html You should be able to adjust rear camber with stock ones this way.
Attachment: cambercorrection.jpg (51754 bytes, downloaded 662 times)
Eikon
Super Moderator
hidden
4-24-2004
| « Re: (94_240sx) | 9:39 PM 9/29/2006 |
My RB setup should actually have less weight over the front wheels than the stock KA did. The RB20 stock is only about 50 lbs heavier if I remember correctly. With my custom manifold saving a few and a battery relocation saving a lot.. i think it will be equal to or better than stock. I would love coilovers.. but I don't have $1k for a decent set. So I found a used set of KYB AGX with Eibach sportlines for $250 shipped. It's not the final product, but it will tide me over until I can afford coilovers.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: Eibach Sportline springs (brokeAs240sx) | 9:31 AM 10/9/2006 |
| Quote, originally posted by brokeAs240sx » | For coilovers, in my case KTS coilovers from SPLParts, you may need to bend/hack/saw part of the rear firewall/rear seatbelt supports. The adjustment knobs on these coilovers get in the way when installing them.
Okay, I pulled out stock struts and yes, I have to bend/hack/saw the metal panel. With a stock strut, I have like 3/4 inch space between frame and top of the strut, but I need like an inch more to clear coilover. I tried to remove rear seat belt assembly for better access, but it won't move even though I removed a large bolt underneath it. Is top portion welded on or something? Anyway, I took some pictures, so I'll post them tonight. Hopefully, those pictures will give some ideas to people planning on getting aftermarket colilvers and struts... I don't have any power tools, so I guess I'll just use saw, punch & hammer to cut and bend it.
Modified by 94_240sx at 1:42 PM 10/9/2006
slip69
94 240sx convertible, 07 Dodge Charger
Watsonville ca
11-4-2005
| « Re: (94_240sx) | 9:53 AM 10/9/2006 |
is it necessary to replace the stock shocks with aftermarket when using springs to drop the car???or can they take the abuse the springs will give them???
onosqv
Q to the V
bewbews.com
8-7-2002
| « Re: (slip69) | 10:05 AM 10/9/2006 |
| Quote, originally posted by slip69 » | | is it necessary to replace the stock shocks with aftermarket when using springs to drop the car???or can they take the abuse the springs will give them??? |
Not necessary if you don't mind riding on blown struts. The general rule is anything lowering more than 1" or so should get better shocks (agx, higher end tokico, koni, etc). Another thing to consider is that your stock struts are probably already blown, they are 10-17 year old struts...
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (slip69) | 10:08 AM 10/9/2006 |
It looks like cutting and bending is required for most aftermarket coilovers. Not sure about other struts like KYB AGX, GR-2, Tokico Blue or Koni Yellow. If you just want to swap the springs, no, you just take out the struts, replace springs and reinstall them. I removed both side of top well(leather?) which is glued on and had a better access for the rear nuts. Space was vert tight. It's going to be a nightmare to adjust the dampening. I would definitely swap stock struts with AGX or something. If you search, you will see most people say using stock struts with aftermarket lowering springs is not a good idea.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 1:39 PM 10/9/2006 |
What is the best way to saw/hack/bend this rear support frame? From trunk or wheel well? I'm asking this because I have no slack/space from rear seat area.
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 5:46 PM 10/9/2006 |
Difference between stock rear strut and Stance coilover...
Attachment: IMG_0306.JPG (106087 bytes, downloaded 584 times)
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 5:48 PM 10/9/2006 |
This is what I have to saw and bend. It's right in the middle.
Attachment: IMG_0316.JPG (69273 bytes, downloaded 568 times)
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 7:39 PM 10/9/2006 |
Done. It was like 10min job. I did it from back seat area.
Attachment: IMG_0351.JPG (67010 bytes, downloaded 543 times)
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 7:42 PM 10/9/2006 |
Used these three... I wonder if this is necessary for aftermarket struts especially KYB AGX.
Attachment: IMG_0357.JPG (36630 bytes, downloaded 533 times)
Hijacker
240SX Moderator
'92 240sx Convertible
Roanoke VA
8-13-2003
not with AGXs.
-Bart
| Quote » | Originally posted by Movingviolation240 What hammer, all I see is a Poundometer, it's a percision adjustment tool. |
| Quote, originally posted by audtatious » | Hey wait. My balls don't hang too low yet |
S13 Auto -> Manual Swap / My 240SX / Convertible Top Replacement / Silvia Fog Light Wiring / DIY: SR20DET Rebuild Stacey L. Childs, NICO Mom
94_240sx
'Vert Encyclopedia
Online
94_240SX
TX
2-28-2005
| « Re: (tenkawa_akito) | 6:26 PM 10/28/2006 |
You see this plastic seat belt housing? It's on the right side on passenger side, but on driver's side, it's still on the right side and your coilover knob will hit it really bad. You have to cut the corner carefully, so the belt will function right. I used dremel with cone shaped grinding rock. For the driver's side, you have to bend the support and cut this out.
Attachment: 345.jpg (21858 bytes, downloaded 457 times)
