cheap_sticker05 wrote:Thanks for all the info. Am I missing something though? The gf210 say they lower 1.5 fr and 1.0 rr.The Eibach sportlines say 2.2 fr and 2.1 rr. Does anyone know if the sportlines are in fact a lot lower?
If you want more drop, go with Sportline. If you want decent drop and performance, go with GF210. If you want performance, go with RSR. If you don't want any headache, Nismo S-Tune is also a good choice. Sportline is progressive, so I've heard that your car becomes unpredictable when hard turn. Spring rates become different right and left due to weight shift. On the other hand, linear sping rates will remain same, so handling should be better. Sportlines gives more drop, it means you will have more chance blowing up your shocks. Stock shocks sometimes blow up if you use Sportlines. One of S14 guys installed Sportlines, front drop was too much, so he swapped just front springs with Prokits and they raised front little bit. Drops you mentioned are based on hatchbacks and coupes, not on verts.
Eikon,RB weighs more, so I wonder how you car will look like after the installation especially front. If I were you, I would go with coilovers. That way, you can have more adjustbility.
brokeAs240sx,I'm going to install Stance coilovers in the back tomorrow along with SPL RUCAs. Front ones already went on with no problem. I didn't know I have to bend/hack/saw... Dang... I'll see if I can get away with Satnce coilovers. I'll try to take some pictures, so you guys can see. I've talked to Kuah w/SPL and Rob, Eric & Eric w/Stance and they had no idea about coilover installation on a vert. None of them seen their coilovers on a vert in person or worked on it.
Speaking on RUCAs, do this if you lower your vert. As far as I know, this is what attwater had to do too.
http://www.240sx.org/links/ins....htmlYou should be able to adjust rear camber with stock ones this way.
