I wanted to put this together as a go to for those interested in the different types of strut / spring options out there for our cars.
Lowering Springs
Tein (3.5 ONLY)
Drops your car about 2 inches all around
H&R
2.5L: 1.2 inch drop all around
3.5L: 1.5 inch drop in Front and 1.2 inch Rear
Eibach
Lowers fronts 1.4 inches and rears 1 inch
Racingline
Front: -1.6
Rear: -.75
Coilovers
D2
I called D2 and asked if they go lower than BC's and the rep I spoke with said that they go just as low. According to Flores45, D2's do go lower than BC's though (compared side by side). They're true styled coilovers (the rears are also a spring on strut setup) so its not hard to believe as to why they can go lower than BC's.
Megan
If I were to buy coils again, I'd probably go with these or D2. A couple of people have decided to go with these recently and they're pretty happy with them. What really catches my attention is their spring rates of 8kg in the front and 10kg in the rear. I think 7kg all around (standard application) is a little too soft for my liking and I'd love to try something more stiff.
BC
A good and well established brand. Probably one of the more popular choices after Tein. But a lot of people have minor problems with them here and there. Check out this thread: comprehensive-bc-coilover-thread-all-is ... 18-30.html
Tein (3.5 ONLY)
Tein is known for having "good" ride quality compared to BC but they don't go as low.
Street Basis
Sedan:
Strut height difference from OEM Struts: -1.57 Front / -0.98 Rear
Max Front Height: -1.1
Min Front Height: -2.13
Max Rear Height: -0.12
Min Rear Height: -1.81
Coupe:
Struts: -1.57 Front / -1.69 Rear
Max Front Height: -1.06
Max Rear Height: -1.02
Min Rear Height: -2.72
Super Street (NO UPPER PILLOWBALL / CAMBER ADJUSTMENT)
Sedan:
Strut: -1.54 Front / -.98 Rear
Max Front Height: -1.14
Max Rear Height: -.08
Min Rear Height: -1.85
Coupe:
Struts: -1.57 / -1.69 Rear
Max Front Height: -1.18
Max Rear Height: -.79
Min Rear Height: -2.76
Ksport
Ksport seems to be a bit unpopular with our car, at least on these forums. But I've heard a lot of good stuff about them on other car platforms. Not sure exactly but from what I've been able to find they have spring rates of 9kg in the front and 4kg in the rear which seems a little odd.
