I have an S14 sr20det with matching trans. I just replaced the clutch with a SPEC stage 3. Also replaced the flywheel. I fired up the car for the first time the other night after the install and put it in gear and nothing... Car didnt move at all. It goes into any gear you want but will not go. I checked the drive-train and everything is good so that is not the problem.
I climbed under the car and hit the release fork slightly with a hammer and it slowly released. I fired up the car with out putting in the clutch (Bypassed the clutch pedal sensor to do this) and it wouldn't go into gear which is normal. I slightly pushed in the clutch pedal just enough to put it into gear and then the car started to move upon release. But once i put the clutch pedal back in the original problem occurred. i went under the car and sure enough the release fork did not come back and was stuck in the disengage position.
Im hoping this is an adjusment issue and not something i did wrong on install. Any help would be greatly appreciated. The build can be found here j14cm7-s-s14-kouki-conversion-build-t472918.html Like i said i dont ask for help often but i searched on this site and google and found that people were having the opposite of this problem.
Thanks in advance
