180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Apr 11, 2004 10:21 am
Byron I've got some tips. First of all Kragen's tools do suck arse.
1. To get the pilot bushing out, you may have to cut it if it's really stuck in there. Usually though, I have gotten away with hosing it down with valvoline synpower penetrating grease and then using the pilot bushing puller I got from Sears.
2. When installing the flywheel, put that one on first, line up the clutch, insert alignment tool and then put the pressure plate on top of that. Make sure though, that the threads in the flywheel aren't cross threaded if you're having a hard time getting it in/out. Otherwise, you may just have to rotate around the pressure plate to get that proper fit.
3. The top bolt, many have wrestled with this and spent alot of time with it. Get the other bolts on first. When you're down to that last bolt or two at the top, let the jack that's holding your transmission release. It'd probably be best to loosen the nuts at the bottom of your motor mounts when you're doing this too (it'll make the install of the transmission easier when you're trying to get it in trust me that's the hardest part). The weight of the transmission will cause your motor to lift a little and will give you enough clearance to get a crazy super long extension in there to drive the last bolt in.
Good luck with getting the transmission in btw I usually rotate my trannies 90 degrees on the sensor side and rotate while I'm trying to install the damn thing for another tip.
