IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Jan 09, 2004 10:36 am
have a buddy get in the car.
pull back the dust boot.
have him push the clutch in and hold it.
check to see if the slave cylinders piston is expanding, then contracting while the clutch is being held down.
if it is, and leaking fluid, the slave is bad.
if it is, and not leaking, the master is bad.
also, trace the steel line from the master to the slave and make sure there are no leaks.
