clutch install wth now
Keachj06
Car: 1989 Fastback SR20DET
i got a stg 2 spec clutch and a lightweight fly, for some reasons the dowls on the flywheel arent lining up with the spec clutch, whats goin on, i checked the part numbers and there all right, is there something iam missing here, let me know.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Rotate the clutch on the flywheel, many times clutches will only fit on one way, you will need to keep rotating it until you find the correct alignment.
Keachj06
what if the pegs are off just a lil bit and then with some tapping with a rubber mallet they go into place
codyace
Car: S14 w/redtop
Sounds like it's an issue with the paint/powercoating on the clutch...
sounds normal to me, take pics though and post if you're really not sure.
