NISTECH wrote:if the hydrolics were the problem it would be consistantly bad not fluctuate with one exception. The master cyl. is the exception. If it were to have a fluid by pass problem. You said its new so its most likely not the problem. From your description especially the info you provided in your second post I am thinking pressure plate problem or fork alignment problem. If it were fork alignment there would be noise associated with it.
I having this issue now with a newly installed clutch and new slave cylinder. Like PapaSmurf, I can clutch and shift when first starting up without any issue, but after a bit of driving, and it seems that it has warmed up a bit, it's as if the clutch isn't disengaging and I start grinding gears. In fact, I've stalled out, and started with the car in first gear, clutched in, and the starter will start the engine and the car will move forward as if i have the clutch partially engaged/disengaged. Can you explain why if the pressure plate isn't installed correctly it would cause this issue, I mean why it takes some time for it to kick in, and then after letting the vehicle cool down, it'll work again? Thanks.
PS, I did bleed the system at both the dampner and the slave cylinder. I'll have to double check and bleed again tommorrow cause I ran out of daylight. Also PapaSmurf did u ever resolve this issue?
