PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sun Oct 26, 2003 9:49 am
OK, heres the problem. my clutch fluid is turning black, and my pedal will build up pressure, and the engagement point will move all over the place (starts near floor, and then moves up high), after it is at its highest point for about 20 minutes, i will go to shift, and it will have almost no pressure at all, and the engagement point will be right on the floor, and i baisically have to force the transmission to go into gear. I have adjusted the pushrod many times, as well as the freeplay screw, both seem to have no effect on this pattern.Heres what i have:Master Cylinder less than a week oldSlave cylinder less than a week oldDOT 4 brake fluidDual friction clutch and pressure plate (although that shouldnt matter because its a hydraulic problem)system has been fully bled many timesI replaced my master and slave cylinder about a week ago because my slave cylinder began to leak, and i also noticed that the fluid was black. before i had done that, i replaced the master and slave about 7 months before.while it does this pattern of moving the engagement point, and then loosing all pressure, the fluid level stays constant, i havent lost any fluid since the master and slave have been changed. Im starting to get pissed. What is up?
