Climate control bulbs
Que-45
Car: 03' Y34 Black/Black
Anyone know where to get the tiny bulbs that illuminate the climate control buttons? Mine stopped working, so I bought another climate control and only like 1 of the buttons light up. I noticed the factory bose head unit did the same thing. I looked at pep boys and they didn't have them.
96Qowner
Car: 1996 Q45
See if this helps:
zerothread?id=225588
Climate control bulbs instructions:http://fuzzycats.com/j30_diy.htm
go to the AC control PDF
The bulbs in the cruise control are soldered in. They are harder to replace. It's easier just to buy a new or used cruise control switch and pop it in.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Que-45 wrote:Anyone know where to get the tiny bulbs that illuminate the climate control buttons? Mine stopped working, so I bought another climate control and only like 1 of the buttons light up. I noticed the factory bose head unit did the same thing. I looked at pep boys and they didn't have them.
If the bulb assemblies look anything like these in the pic they can be replaced with the Radio Shack bulbs. You have to unwrap the two leads and pull the old bulb out, reinsert the new bulbs and wrap the leads in the same way, and then trim off the excess. Easy fix.
I just parted out a 91Q and thought I had removed these bulbs from the back of the climate control unit so they should be replaceable. I've replaced the bulb in my dashboard cruise control switch also so it is repairable as described above since the stealership doesn't sell the bulb assembly separately.
Modified by goody94q45 at 3:11 AM 11/20/2007
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Mike- did you blue tint, or just go with the brighter white where it used to be light blue?
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
A job I have to do, as my buttons haven't lit up since I took ownership of the Q.
goody90q45
The blue material is just a rubber shroud- It will pull off the old bulb and go right on to the new bulb. Some assemblies have it and others don't.
Que-45
Ok, that looks pretty easy. I'll go to radio shack today then. I figured scottsdale infiniti had them, but I wanted to see if I could find them locally.
drrm123
Car: 1991 Q45
here's another link to a company that sells blue ones http://autolumination.com/74.htm they're about half way down the page 10mm X 13mm
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
sry to bring this out of archive, but im taking these wont work.. http://www.directron.com/5ledgreen.html I manage to shave the bottom of em so i can get em in, but when i turn on lights, the climate control area started smoking.. I saw em come on, then they went off.. And i started smelling burned electricity.. i took em out immediately, and now im wondering this... If i order from Scottsdale, will that come with a new brown thingy, or is that only the bulb that they send.. Cause there doesn't seem to be a cheap way around this.!
Q451990
Those are LEDs... not bulbs. So yeah, they will burn out almost immediately when you put a full 12V on them - vs. the 3.? they're supposed to have! The bulb assemblies from Scottsdale should have the base.
Heath
gammer_ghn
Q451990 wrote:Those are LEDs... not bulbs. So yeah, they will burn out almost immediately when you put a full 12V on them - vs. the 3.? they're supposed to have! The bulb assemblies from Scottsdale should have the base.
Heath
hey buddy have you heard of 12V LEDs those things dont burn give em a try ebay has some = ]
goody90q45
I fixed the link to my pic in this thread showing the 12v micro lamps available from Radio Shack. Here you go:
Romeo5k
Thank You bud.. im making the call now..!! You helped BIG Time with that pic.
Q451990
I have... they are LEDs with current limiting resistors built in. But there's no drop-in replacement in this application that I'm aware of - as in, thread it in the base and you're ready to go. If anyone has one, I would love to see them!
Heath
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
just did my cc with these bulbs last week, takes 30 minutes round trip, i did not tint my bulbs but u can w/ some paint or nail polish.
been 2 yrs since i had lights in cc, what a pleasure, may still tint them
goody90q45
Romeo5k wrote:Thank You bud.. im making the call now..!! You helped BIG Time with that pic.
Thanks. That pic's come in handy at least a few times. It shows it all.
Q45man1
Car: 2002 Q45, 1994 Q45
Most of the replacement LEDs that are available are 12V and 24V, but in wedge based in T-1 3/4 & T-3 1/4 package only. And you can get them in different colors. They are design to replace some of the incandescent lamps found in cluster instrumentation, audio amps and mixers. 7219 is a wire terminal (radial lead) bulb but we haven't design a replacement LED for it.
Ozzie
'06 MK5 Golf tdi
Old thread revival!!!
I did this job, using LED's instead of incandescent bulbs, and am quite happy with the result....
Look here.....
zerothread?id=235041
Modified by ozzie! at 10:10 AM 11/24/2007
Romeo5k
i did mine yesterday and im happy.. I didnt put those blue caps back on here... it looks alot brighter with that thing off.. Unless i get colored bulbs then meh. This si good enuf.. Thanx all.
Ozzie
'06 MK5 Golf tdi
Send me your old climate control unit, and I will repair it and return it for cost...I will replace the bulbs with LED's, which shouldn't burn out for the rest of the life of the car!
