mr_wizard »
https://forums.nicoclub.com/mr-wizard-u33966.html
Sat May 13, 2006 6:07 pm
Check all your grounds. Check the voltage on your battery, should be 12+ volts. Make sure all your electrical connections are tight. Finally, next time it doesn't start, hit the starter a few times with a hammer, it's possible the starter isn't disengaging properly... hitting it will make it disengage. Do this while someone tries and starts the car. I gaurantee it's 1 or more of those problems. Good luck.
