agreed timing wouldnt have changed on its own normally. i have this car for almost 3 years, and never had this problem.zsmizzy wrote:its timing. redo dizzy timing and try it again. mine did the same thing.
umm pg 161 in that link, talks about high idle after warm up. and doesnt contain ignition coil or anything on the page.... and yes i checked codes, i got 5 long blips, and 5 short blips, which SPLINTERCELL told me was good and nothing is wrong as far as codes.OutToWinPAHC wrote:http://www.nicoclub.com/FSM/240sx/91-94/EC.pdf
Page 161 how to check your power transistor and ignition coil
The controller is the ECU which used other sensors. Have you checked codes
