Clicking heater fan
westiedriver1
Car: '15 Nissan Rogue SL
2015 rogue SL Fan sounds like helicopter When I start engine the fan will click, if heater is selected on before starting . If I turn off the heater off before starting engine every thing works normal Any ideas what going on?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If a leaf or pine needles are stuck in the blower, a lot of times they'll be most noticeable when the blower spins up and much less noticeable when it reaches speed. Bad nose bearings can do the same thing, letting the cage contact the housing until the speed comes up. Either way, you probably need to clean out the blower cavity and inspect the cage and motor.
westiedriver1
There no noise at any speed when it's turn on after starting the engine. I will try and check blower. Is it behind the glove box?
VStar650CL
Technical Expert
Yep. Once the glove box is out, it's up at the top of the HVAC box. Only one screw holding it in but it's a bit of a PITA to get at. This thread has a clear pic:
2017-rogue-blower-t624792.html
westiedriver1
OK thanks for your help
Return to “Rogue Forum”
