Yep:Wangtang408 wrote:I tried looking into changing all the orange lights cluster, dashboard, illuminated kick plates...
Those parts are hard to find unless you find a used 08+ M that is being parted or you can buy them from the dealers.
I gave up on this project but good luck to you. Dean was able to change his cluster I believe he posted a pic on one of his threads.
I agree that it is insane to do but that's me:msvara wrote:Ah. Never took any photography classes. I still think there may be a way to block the amber and have a blue. You're probably right about the decrease in intensity. I would do this but the thought of taking the entire interior apart just to change the leds is insane.
DeanM45 wrote:All lights (in the cluster and switches) are surface mount LEDs. Unless you are VERY good at de-soldering and soldering you will need to but the 08+ pieces. The only bulb you can switch out easily is the shift indicator.
