JJ240 wrote:Just so you know retaining heat in the headers helps the exhaust gasses escape. When hot the gasses expand which leaves less open space so theres less turbulence. It increases exhaust gas velocity which does help the exhaust flow. And as far as saying pacesetter are crap that is somewhat ignorant. I have heard people say things about hotshot fitment too and yes they own them. 320 dollars for one header for a 4 cylinder engine is excessive. A set of nice hedmann headers for an 8 cylinder mustang doesnt even cost as much as hotshot for our car. If you buy a set of pacesetter headers just strip the black paint on them and put on some nice ceramic based high temp paint. It will last and prevent them from rusting. They flow better than stock although maybe not quite as much as hotshot or S&S. For 150 dollars +5 dollars for a can of ceramic paint I believe it is as good of a deal as hotshot because your performance will be ALMOST as good as hotshot. I dont mind people bashing pacesetter because the product is inferior to hotshot because it is. But to say its pure crap is ignorant. It has its pluses and they are higher performance than stock and high cost-performance gain ratio. FYI hondas arent cheap either they have some of the best engineered engines ever made. people make over 200HP easy on little 1.8ltr Honda engines when we can barely break 200 doing everything possible besides forced induction and re-engineering the head.
I was not bashing hondas in any way! Yes I agree they have some of the best engineered engines ever made. But they also have the largest aftermarket support of any car in existence. If there was even a little bit of that product research put into the KA on a professional level, it would not be quite as difficult to get horsepower out of our engines. It's unfortunate, but that's the way it goes.
But still, Pacesetter is crap. :oface
But buy what you want. If you want $100 headers off eBay, go for it.
