check mi new rb20det intake manifold
nomenai
today i raceive mi new intake for rb20 i looks ok, good quality welding, i ask for hols for the temp sensors and 95mm bore for q45 throttle body.
is this a part of the web page:
This intake manifold give you a lot more power and response in middle range and high range. You can feel the different with this manifold change. This manifold can increase 13% on standard engine and maximum of 40% on fully modification engine. If you have modify engine such as bigger turbo, camshaft modify this manifold is a must for your engine.
nomenai
nomenai wrote:today i raceive mi new intake for rb20 i looks ok, good quality welding, i ask for hols for the temp sensors and 95mm bore for q45 throttle body.
nomenai
intake w velocity stacks
nomenai
3.5 " BIG BORE BABY
Eikon
Car: 71 240z, 93 Supra TT
I don't get it?
Pretty looking manifold, but the tank is pretty small. The idea of the tapered tank is to force consistant air into each cylander. But this one seems to run out of taper by the 4th cylander. I'm a little concerned about leaning out on 5 and 6. Plus, the tank itself isn't very big. Sorry.. I don't mean to knock it... just curious about the though behind it's creation.
The think I really don't get... Why such a huge TB? I thought the RB20 and 25TB's were good to like 550hp..? That TB is almost as big as the tank itself.
nomenai
well in the future i will increase bore and stroke of the engine + i got it really cheap + for some reason in japan and australia they change it for q45's
Carl H
meh, q45 tb is still an overkill tb.throttle response might be a bit on the slow side due to the large nature of the tb.does that intake manifold have reservations for the IAC and the AAC valves?
lucky7
Car: 97 RB25 S14
i have a Q45 TB. i got it because it is a direct bolt on to the greddy manifold i also have. i believe there is an adapter plate greddy makes to use the stock tb. i was getting a q45 maf from a guy who also happened to have the tb. so i just got both for a good deal.
nomenai
yeap all you need
skillzilla
Wow it is definately pretty, wonder if it has been flow tested vs stock.
nomenai
they toll me yes they have bean produce this intake for a long time with very good results
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
They can tell you anything to sell their products. I personally wouldnt buy anything without have some sorta feedback from other customers. But thats just me.
How much did you pay?
But overall nice looking manifold
Just wait until you see mine, wish you would of gotten it for a bit more $$$
nomenai
$420 w shiping thanks i think is a good price
nomenai
nomenai wrote:$420 w shiping thanks i think is a good price
i think we need some kind of evidence. for example test in the same engine 3 o 4 intake manifolds and check real numbers in dino and post the results thay wey every one knows. i use to have an integra all motor and in other honda comunity like this one this is what the do.
what do you thing every one?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
wow. Ok now flip the manifold over to the flange and stick your finger in there. Can you feel a lup where the pipe they welded on to the stock flange? better yet look right into it and see if you can tell where it changed size. I bought a manifold just like that a long time ago, after I inspected it closer I found that I got jacked and gave the manifold away for $140 lol.
These things are not velocity stacks btw
The biggest problem I see is that your going to have to mod the Tstat housing. I know on my rips it came with one. The manifold wouldnt fit without this mod.
nizmo zilvia
Why didn't you get the "JUN" one? That one looks very promising as for the design. As for the welding, who the fuk knows.
nomenai
well i think is going to work great i will post some dinos and videos when i finish all the project. + for the price i think their is nothing out ther ready w this quality and price
Yellow4g63
Good luck.
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
With about 2 hours worth of port work these work well.You must use a big throttle with them as if you use std at higher boost, you actually are blowing across the 1st few runners and creating a vaccum on #2.No guessing.. done on a flow bench.
Chaos the Xile
Car: 1974 Datsun 260Z
not a bad looking mani, hope it works out for you.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
lucky7 wrote:i have a Q45 TB. i got it because it is a direct bolt on to the greddy manifold i also have. i believe there is an adapter plate greddy makes to use the stock tb. i was getting a q45 maf from a guy who also happened to have the tb. so i just got both for a good deal.
Is your car still at "Tuning Factory?" When's that thing going to be finished?
That TB on a 25 is different than that TB on a 20...
nomenai
well i think im going to be finish next month
nomenai
today's work. intake manifold and new turbo garret to4b25. the intake is not direct bolt on you have to modify some hoses make some adjustment's but i think is worthed
nomenai
more pics
nomenai
more pics
Yellow4g63
I see 25% of 2 pics and a huge red x. Upload your pics to Nico and then post the link in the forum.
Carl H
ugh, ditch the fram oilfilter and get something decent...looks like it fits ok, but you will have to fab an intake pipe to connect the turbo to the maf, having the maf on the turbo like that is gonna cause horible turbulance and reversion and give you nothing but problems...just a heads up before you crank it and scratch your head trying to figure out why it runs like arse.
nomenai
new pics today's work
nomenai
more pics
kjlindgr
Wow...lots of haters in this damn forum. Anyway, it looks good and it should do the job. Benefits over the stocker will be seen once it's running. At least it looks better than the ugly azz stocker.
Let's see that throttle cable hooked up now!
