yelnatsch517 wrote:Ok, finally got the chance to do the diagnostic. It turns out its, the O2 sensor, 3 blinks and 3 flashes. Now first off, are there certain brands of O2 sensors I should get? I checked up online and found several brands with Bosch being the most expensive running around $75-80. How important is this sensor to the well being of my car? Also, how hard would it be to change the sensor myself? If its fairly simple, I'll just do it myself.
First steps to being self sufficient car-wise.
O yea, also, there is a little problem with my suspension. The driver side sits a little higher than the passenger side. I have no idea why. It is bad enough that I can tell when sitting down in the driver side with no one on the passenger side (still sits higher with more weight). How would I go about adjusting the suspension (stock)? Should I just go ahead and change it to coilovers (everything on the car so far is stock)?
i dunno where you're looking for your o2 sensors... but autozone sells bosch oem o2 sensors for $32 and universal bosch ones for $17
i would just grab the universal one and save some money... seems to have the same performance... i'm currently running on the universal one right now.
it's very easy to change your o2 sensors... you'll need an o2 sensor socket... which you could rent out at autozone for FREE (just pay a $17 deposit and get it back upon return) then attack the o2sensor which is located on the lower part of the manifold. (it's on the right side if you're standing in front of the car lookin at the engine). if its kinda hard to take off spray some wd40 or liquid wrench and let sit, then attack again.
and on your suspension... check if your passenger side shock is blown... that could probably be the cause... if not then i'm not sure
-David
Modified by deCksy at 5:59 AM 11/16/2004
